wagon elevator clutch 324
GordoSD
On my 324 New Idea corn picker there is a clutch to stop the wagon elevator when turning around. It is not working. Is it supposed to stop the elevator when the rope pulls the arm to the forward position?
How to troubleshoot that?
It will ratchet, not tug forward and stay there. You pullit and it returns to the back position, pull it and it returns to the back position. One pull puts it in gear, next pull putit out of gear, etc.
Often full of old dry grease, or corn debris, a good cleaning, see if the spring is good, and go from there.
--->Paul
Yes. spring is on there and it returns after you pull it.
Does the picker have to be moving? I am just running the pto and the picker in os a slab outside the shop.
