| Implement Alley Discussion Forum |
Topic: Hand corn sheller question
[Return to Forum]
| Author |
[Modern View]
| nh8260
10-04-2012 20:27:56
75.131.172.205
I've got a McCormick Deering hand corn sheller (the 3 foot tall kind) that i want to put an electric motor on instead of having to crank it all the time. Does anyone know what horsepower and RPM motor i would need? Also what is the best way of attaching it, i know the handle and large flywheel will have to be removed, but not sure what to do after that. Thanks a bunch!! |
[Reply] [No Email] | |
| nh8260
10-06-2012 23:23:22
75.131.172.205
Re: Hand corn sheller question in reply to nh8260, 10-04-2012 20:27:56
| this thing has a round piece of metal that goes on the end of the flywheel shaft, it has teeth up in it, i think its to pull or push cobs. I might could run a v belt on it and mount a motor below it so the weight of the motor would keep the belt tight, think that would work? I'm trying to make it so i can put it back to hand crank easily if i ever need to. |
| Tramway guy
10-05-2012 18:16:18
24.92.254.197
| We had one that had the v-belt riding right on the flywheel. Worked very well. 1/3 HP motor, I think. |
| Berth 29 opinions
10-05-2012 17:58:06
68.49.9.180
| Our hand corn sheller had a six inch pulley that was attached to the flywheel with j bolts. |
| gtractorfan
10-05-2012 12:26:16
71.66.229.3
| Long ago my dad fixed his hand sheller with a motor and didn't have to alter anything permanently. He made a large wood pulley, no groove for the v-belt, and used hook bolts to attach it to the flywheel, then rigged a bracket for the motor, the motor had a small probably about an 1 1/2" pulley. I think it was a 1/3 horse. You had to let it keep up, putting in ears too fast slowed down the motor so a half horse would have been better. It was kind of fun to use. |
| paul
10-05-2012 06:46:43
66.44.133.112
| | You'll need to keep the flywheel, it's needed. Some shellers have a little pulley on thenm, looks cogged, but for a belt. Don't know the different brands enough..... --->Paul |
| glennster
10-05-2012 04:51:01
99.90.9.201
| my dad mounted an old steel car rim to the big flywheel, then used a 1/2 horse electric motor to run it. just used a regular v-belt.. made a bracket and mounted the motor on top of the sheller. worked real good. the belt ran in the center of the rim. you could get a weld a hub pulley from any farm store, or shoups sell them. and make your own pulley. about a 12 to 14 inch pulley with a 1750 rpm motor should be fine. i would leave the big fly wheel on. |
| fergienewbee
10-05-2012 04:11:57
99.109.126.246
| | A JD sheller sold for 275 or 300 at a recent auction. It was in good shape and worked great. Larry |
| Bret4207
10-05-2012 04:05:15
64.19.90.196
| If you are going to do it, don't put your drive pulley right on the crank handle, run some sort of jackshaft so there are bearings taking the stress from the pulley and belt. The original design wouldn't be built to accomidate side pull/thrust. You'll wear the crank shaft or frame material out. |
| Dick2
10-05-2012 01:17:31
174.19.205.113
| | How much are you going to use the sheller? If it has any value as a collector's item, you will destroy the value by converting it to an electric motor. If you don't reduce the speed down to the speed that it is normall cranked, it might just destroy itself real fast. There are no high speed bearings on that machine. |
| willie in mn
10-05-2012 00:50:43
67.142.168.24
| 1/4 horse motor should have plenty of power. 1725 rpm on the motor comes to mind. count how many revs you turn the crank in a minute. have an assistant time you while you crank, or the other way around, have assistant turn the crank while you do the timing. 60-75 rpm sounds reasonable. 1725 (motor) divided by 75 (crank) = 23 to 1 reduction. might have to use a jackshaft & do the reduction in 2 steps. now someone with better numbers can jump in & make adjustments to my thoughts. Willie |
| 60 acre hillside
10-06-2012 16:27:37
67.142.170.26
Re: Hand corn sheller question in reply to willie in mn, 10-05-2012 00:50:43
| My dad's cream separatot needed a crank speed of 60RPM. So you are right!@ |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
