TractorLinks.com
Re: 3PH broadcast spreader???
Leroy
10-03-2012 04:20:33
Set it as low a rate as the material will flow through and fill to a marked level and run over a known area and refill and weigh how much it took to do that area. If it only put on 1/4th of what you want repeat and weigh and then do the math. No 2 times will the fertilizer flow exactly the same. Just keep gradually increasing to get where you want and recording what each setting did and where and then after you are completely done with all patches go back over the ones that were light using the figures that you come up with for all settings to get the correct one for to increase the rate put on all of them. You might want to figure the area in say one round at a time in doing the calculations
dave2
10-03-2012 04:55:32
 Re: 3PH broadcast spreader??? in reply to Leroy, 10-03-2012 04:20:33
OK, thanks guys... Even the manual paul linked says more or less trial and error so I won't feel lioke an idiot :roll:
Worse case, how much of an "error" would it take to over fertilize????
Or would I just get greener/better grass???
jackinok
10-03-2012 06:39:28
 Re: 3PH broadcast spreader??? in reply to dave2, 10-03-2012 04:55:32
that would technically depend entirely on the fertilizer of course, but you really have to dump on the fertilizer to actually kill something in most cases. Over fertilizing is not so much the chance of setting your crop back, but the fact that your litterally throwing dollar bills away. It would be rare indeed if even your front yard needs exactly the same fertilizer accross the whole area,so some of it will be over or under fertilized anyway. Too much accross the whole area is simply wasting money because a lot of your nitrogen will be lost. In fact, and this is up for debate,some studies have proven that 99% of the fertilizer folks use is simply wasted with no benifit whatsoever. take for instance that spreader, i assume your using premixed pelletized fertilizer.good stuff if used correctly,but are you just going to spread it on top? if so most of your nitrogen is going right into the atmosphere,or is running off into a stream. a sprayer and liquid fertilizer,would be a better choice in this case. Its cheaper and will stay in your yard,and is in a form plants can use now. Not trying to tell you how to run your buisness here,i use one of those spreaders myself. but only when i can work or water in fertilizer. if you do use this,water it in good when your done spreading.youll still lose some but less than you would if it just laid on surface. many many folks,will tell you it simply doesnt pay to fertilize pastures of native grass and things. thats simply not true.how you fertilize is just as important or more so than what you fertilize with.like i say using one of these improperly is just like throwing money in the wind. if your fertilizing pastures with one of these,do it immediatly before or better yet DURING a light rain (The cover is a VERY important piece of this equipment).grass cant use fertilizer laying on top the ground,no plant can. the longer it lays on top of the ground the more you lose.
