| Implement Alley Discussion Forum |
Topic: wheel bolts to drive in wheel studs?
[Return to Forum]
| Author |
[Modern View]
| workhorse66
09-30-2012 08:14:31
12.175.19.11
The threads on the hub are worn and lug bolts won't stay tight on gravity wagon gear is there a drive in stud out there to convert these over to lug nuts without re drilling the hub? just drive into existing threads? Does nappa or mutual wheel make a reto kit? |
[Reply] [No Email] | |
| evilboweviel
09-30-2012 12:53:41
75.185.55.222
Re: wheel bolts to drive in wheel studs? in reply to workhorse66, 09-30-2012 08:14:31
| sounds like time to helicoil the hubs |
| Michael Soldan
09-30-2012 12:28:30
24.235.36.51
| I ran into that witha running gear,I got new studs at Napa but the holes were worn just enough that the studs would turn when you tightened the lug nuts,we just spot welded the back of them,they been on that wagon like that for over twenty years |
| thurlow
09-30-2012 14:30:31
74.177.51.31
Re: wheel bolts to drive in wheel studs? in reply to Michael Soldan, 09-30-2012 12:28:30
| Have fixed many-a-one by doing that, sticking a stud through from the back and nickel welding it in. |
| wisbaker
09-30-2012 11:18:14
184.157.215.49
| Probably wouldn't be that hard to find hubs to fit your spindles and switch them over that way. I don't know how much experience you have fixing stuff I'll share a few thoughts-drilling or reaming them for studs sounds like a sound idea but getting the new larger holes exactly where they are supposed to be could be difficult,if they're a bit off your wheel may not be centered and it's going to hop when you pull it at any speed, this might be a job for a machine shop and someone still has to figure out if the hub has enough meat to bore out the stud holes and not get weakened in the process. Bolts through from the backside may have merits, just make sure the bolts you use are as good or better than wheel studs or lug bolts or you could have wheels flying off, there's never a good time for that. I guess I'm saying the safest way is new hubs, from there it's your wagon, you know how much weight you haul, how fast and far you pull it, how much your cargo is worth, how much you have to loose if the patched hub fails and injures someone and your risk tolerance. |
| JMS./MN
09-30-2012 10:52:04
209.237.125.241
| Get longer wheel bolts and put a nut on the back side of the hub. |
| Leroy
09-30-2012 18:48:26
69.88.205.38
Re: wheel bolts to drive in wheel studs? in reply to JMS./MN, 09-30-2012 10:52:04
| That is what I have done. |
| JMS./MN
10-01-2012 23:33:28
209.237.125.241
Re: wheel bolts to drive in wheel studs? in reply to Leroy, 09-30-2012 18:48:26
| Only bugger is to remember there is a nut on the backside when unbolting!!!! Did that on the loader tractor years ago....also a Gleaner F2 combine.....so as long as I remember those two machines.....ok to go! |
| OH - 961
09-30-2012 10:33:49
66.19.62.191
Re: wheel bolts to drive in wheel studs? in reply to old, 09-30-2012 08:14:31
| And a generous dab of red Loctite to keep them in place!
Myron |
| RayP(MI)
09-30-2012 09:27:50
207.241.137.116
| I would try bolts with the same diameter and thread, run them in from the backside, if there"s enough room. Probably enough thread to hold them in, and head against hub willl prevent pull out. |
| DeltaRed
09-30-2012 08:44:48
67.6.219.50
| Not that Iam aware of..But it doesnt take much to drill/ream out the holes on a cast hub. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
