New holland 273 parts needed
Does anybody have a 273 that they are parting out or know of a salvageyard that deals in used baler parts. I need a knotter assembly or the main knotter frame.Thanks jordan
Think that is the same knotter as on several NH balers. Don"t remember which ones are common... Maybe someone has that data off the top of their head - Would improve your search if you could search several models.
The "small chamber"(14x18) balers all used the same knotters.Iam not totally sure, but I belive the "big chamber"(16x18) balers also used that knotter.The needles between the big and small are different.
The 273 uses the standard knotter which is found on all balers except the big chambers starting in the 80's and the 326 and 575 which have the heavy duty knotter.
Jordan,
I have had excellent results acquiring used and aftermarket parts for my NH 273 baler from:
1. All-States Ag Parts. They have a network of dealers. I've gotten parts from their dealers in Wisconsin, Minnesota, and Iowa, Google their name and you'll find a phone number. The one that I always start with is (877) 530-4430.
2. Fry's Machine in PA. Their number is (570) 546-3968.
I'd be shocked if one or both of them couldn't fix you up.
Tom in TN
