Topic: Help Identify Old Bushog
[Return to Forum]
| Author |
[Modern View]
| ARHunter
09-23-2012 07:28:05
24.119.244.114
I am trying to figure out what model Bushog this is. I know it is probably at least 40-50 yrs old. Any help would be appreaciated.
Also, the input shaft seal leaks and I have read you can fill these gear boxes with grease. Would it be better to do that or fix the seal? Thanks
| John Mason, Michigan
09-29-2012 18:16:45
75.210.250.51
Re: Help Identify Old Bushog in reply to ARHunter, 09-23-2012 07:28:05
| Any of you guys know anything about Mono Mfg, brush hogs? |
| ARHunter
09-24-2012 14:37:23
24.119.244.114
Re: Help Identify Old Bushog in reply to jon f mn, 09-23-2012 07:28:05
| Quoting Removed, click Modern View to see
Yeah, I guess I should go ahead and replace the seal. It shouldn't be too much trouble.
It seems to be in fairly good condition except for the deck being cracked in a couple of spots where the front vertical bars connect. I beefed that area up with some 2"x2" angle iron. Replaced the bearings and seals in the tail wheel hub and put on a new tail wheel. Used it all day last Saturday and never had a problem. |
| Billy NY
09-24-2012 09:50:54
24.29.79.122
| | Besides the surface rust, it sure looks like it had an easy life and that is definitely an older gearbox judging by the looks. I can't believe how straight the deck is, not even a circle imprint from the blades like most eventually get. See what info you can get off it, might find literature for it on ebay or similar. There was a post on here about Grease vs 80W-90WT oil in these, my old Rhino SE-6 actually called for 0 or 00 which is heavier than 80W-90, less viscous and almost like track roller lube which is a stringy tacky type lube, almost reminds me of chainsaw bar oil. Someone made a point about grease that I thought was good, I would not use it, unless nothing else was available, fix the seal and used the appropriate lube, its designed for splash lube applications which is what the differential/gearbox is. One of the reasons I would prefer to use the heavier oils is for maintenance, mixing greases and oils, incompatible soap bases and whatever else, has the potential to make a mess, when I want to change the oil on mine, I flip it over, drain it, and refill with Lucas 80W-90 or whatever grade, (I forget at the moment) but is stays clean and does not leak, I'm sure the seal has plenty of miles on it too ! |
| ARHunter
09-23-2012 08:12:26
24.119.244.114
Re: Help Identify Old Bushog in reply to DeltaRed, 09-23-2012 07:28:05
| Thanks for all your help. I can change the seal on the input shaft, but if the thin grease will work and not leak that would be a much easier solution :) . |
| James Howell
09-23-2012 07:59:35
75.224.232.219
| | I agree with the real roger that it is a 5ft Model 12 mower.
Got one just like it down by the equipment shed. |
| ARHunter
09-23-2012 07:54:24
24.119.244.114
It is 5 foot. I think it may be a model 12 just wasn't sure. What about putting grease in the gear box. Any opinions on this? |
| James Howell
09-23-2012 08:08:48
75.224.232.219
Re: Help Identify Old Bushog in reply to ARHunter, 09-23-2012 07:54:24
| | You can use Corn Head Grease that is available from Deere.
Used it to stop a leak on the JD #5 sickle mower.
Used it a couple of weeks ago to stop a leak on the 7ft Corsicana rotary cutter. Hope this helps. |
| the real roger
09-23-2012 07:48:17
72.23.72.14
| What size is it? If it is 5 foot it could be a model 12 |
| BigMarv1085
09-23-2012 07:39:33
74.190.11.43
| The gear box looks the same as a Bushhog 706, have you tried to run the numbers on the back bottom of the gear box |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
