Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD #52 - What should this part look like?
Badger08
09-19-2012 19:14:46
Brandon, I actually tried the plow out tonight. The previous, previous owner had taken the furrow steel wheel and cut it off and put it on rubber. So I found a steel wheel and put it back on full steel. So then I thought I might as well try it out even though getting dark. I tied a string onto the clutch lever and ran it through the loop on one of the levers and to the tractor and attached it with a piece of wire. And sure enough I made a round and was turning around and the dang thing unhooked and the wire trick worked and it simply just pulled the rope outta the wire. Then just rehooked it and went. Other then that it worked fine. Now just to get it adjusted up right to ride in the furrow and get it leveled a little better and will do some plowing with this plow and my 44H. Thanks everyone!
Copyright © 1997-2015 Yesterday's Tractor Co.
