Tire Size for JD/VB FB Drill
Briar Hill Brittanys
Location
Near Jasper, MO
What size tire is supposed to be used on an FB model drill. The ones on it now, and were on it when I bought ir are 9.50 - 15 implement tires, and seem pretty tall. Sometimes I can look back and see a boot or two in the air an inch or two. On the places that are nice and level I don't see that. Get in any parts of a field that have small ridges and the seed drops on the surface. I guess the cover chains drag enough dirt over the seed to get it to germinate. Mark
I think ours has 7.50 x 15, which is the largest tire size listed in the manual.
Donovan from Wisconsin
The 6 lug wheel for a FB drill is JD894(subs to a JD680) which is a 5"X15" so 6.70X15 is correct for a FB also. As stated a larger diameter tire will cause drill to put out less seed than chart shows.
