467 baler net wrap actuator
Anonymous-0
My 467 net wrap actuator is stuck in the engaged position. The actuator engaged to wrap the bale but a low voltage problem wouldn't let it disengage. I corrected the low voltage problem but the actuator is still engaged. How can I get it to disengage? Thanks..Dan
Im Thinking that you will have to go into the channels in the monitor and then press the extend and retract, i cant think of the channel right now that it is, maybe 14 or 18
Thanks for the reply. I ended up using my battery charger and reversing the polarity on drive motor and it backed right off. Thanks again.
