Krause disc
Pitalplace
I have a 8ft Krause disc that needs new bearings. They are a cast bearing with part # H142 on them. Anyone have a source?
Thanks
(quoted from post at 11:40:16 09/12/12) Krause dealer?
Tried that, it's to old and the parts are no longer made. Talked to a couple this morning. Looks as if I will be looking for some better used ones.
If you can't get them from Krause anymore, check to see if any of Agri-Supply's generic cast bearings will work. Can't post a link here but a google search will find them.
I would think a good bearing supply house could order them if they are not in store. BUT they may be expensive that way.
I have never seen a Krause with this type. I have an 8ft Krause tandem with the ball bearings. It has round axles. I imagine you could get the half spools used with the new type bearings to match your spacing and axles. The spools are offered aftermarket also.
Try Shoup Parts. They have a lot of disk parts. You should call them because their on line catalog does not list everything they have.
