Ford 515 Sickle Mower
Jay Dub
New User
Need to find a replacement spring assembly and belt. The spring assembly controls the cutter arm tension when lowered. My spring broke. Or...need someone with the knowledge and equip to re-screw the adjustment rod nut back into the spring.
I can't help with the spring but I've got one of those mowers and I can tell you that there are 2 different belt lengths. It depends on the width of the frame as to which belt it uses. CNH usually stocks them around $60.00 but I crossed the belt over to gates and rockauto has the belt for $34.00 last time I looked.
