JD CCA field cultivator
wijim
What size tire came on them new. And what size truck tire can replace them. Wheel size is 15x4.5 Thanks jim
Looks like my JD CC field cultivator has 6.70 x 15 tubeless car tires on it. They look to be the original tires as all the thread is still on them. My serial plate is stamped CC so not sure if this is the same as a CCA. I occasionally use it to work up the stuble in my wheat & oats fields and to excerise by JD 830. Al
Smaller sizes normal was 6:70 used auto tires you provided of your car while larger sizes was 7:60 same way. Parts book will tell wheel width to total width. First was the CC with steel wheels, then the CC147 either way and 15" or 16", that the CC-A. Built from mid 30's to late 60's.
The tag on mine is CC A its a trip lift 12ft. I'll look for some used tires this week. Thanks all, Jim
