| Implement Alley Discussion Forum |
Topic: Setting spring trip plow
[Return to Forum]
| Author |
[Modern View]
| Super Steve
09-02-2012 12:45:37
209.239.18.44
So i ended up buying a Ford 151 4 bottom plow. They are calling for rain later this week but id like to get the ground plowed so i can get some hay planted before the rain but the ground is so damned hard i cant keep the furrows from tripping. My plow has the dual spring resets on each bottom, my question is, how tight can i put those springs and still be safe? theres 4-6 inches of threads that i can tighten down, its set about halfway of a touch less then half |
[Reply] [No Email] | |
| flying belgian
09-03-2012 13:25:28
98.132.233.132
Re: Setting spring trip plow in reply to Super Steve, 09-02-2012 12:45:37
| Yes dry hard ground will make them trip without hitting a rock. I had the same trouble last fall. Instead of changing everything only to change back when you return to more normal rain patterns or even a different field, I just set the depth a little shallower. That solved the problem for me. |
| Super Steve
09-03-2012 14:03:24
209.239.18.44
Re: Setting spring trip plow in reply to flying belgian, 09-03-2012 13:25:28
| thats what i ended up doing today, the furrows still tripped the odd time but not constantly like before |
| jon f mn
09-03-2012 04:58:05
70.198.3.173
| I think the spring adjustment you are seeing is for how hard the bottoms reset once tripped, the breakaway setting should be a shim under the part where it stops against the beam. Not sure what it is on your plow which are the same as oliver and case plows of that vintage. On our Melrow plow they had a half moon shaped stop that you had to change and Jd plows had shims you could add or remove. I think yours has shims too. We had the same problem you are having with our Melrow in our heavy clay, it would sometimes trip all 5 bottoms at once til I got new thinner stops. |
| dboll
09-02-2012 17:29:21
64.61.211.158
| don't know how they do things your way but around here we never plow before planting hay as you can't make a good firm seed bed,if you haven't used it how do you know you have a problem? |
| Super Steve
09-02-2012 17:56:57
209.239.18.44
Re: Setting spring trip plow in reply to dboll, 09-02-2012 17:29:21
| | this is how its done here when fall seeding. I used the plow today and thats what was happening. As for it being set from the previous owner, i dont think it was. This plow was bought new 35 years ago buy a man and used to plow up 60 acres of corn one fall then the man passed away. The mans wife rented the farm out for 20 yeasr until she passed away. The son got the farm when she was gone and hes rented it out for the last 15 years. This plow has been sitting in the back corner of the shed for 34 years. So tonight i went back out and did some measuring, i noticed the front furrow was tripping the least so i measured the spring and thread length on it and it was 2" of thread showing so i set the other 3 to that. Ill go try it again in the morning |
| DeltaRed
09-02-2012 15:22:50
67.6.225.104
| I doubt you will have any trouble with just hard ground.Rocks are where you need trip bottoms.If you tighten them tight enough to not trip occationally in hard ground,it wont trip on a rock.then you really tear things all to he!! |
| Super Steve
09-02-2012 16:02:16
209.239.18.44
Re: Setting spring trip plow in reply to DeltaRed, 09-02-2012 15:22:50
| they arent tripping "occasionally", occasionally they DONT trip and its not just one or 2 furrows, its all of them |
| JDseller
09-02-2012 13:36:34
208.126.196.144
| I would deliberately trip them and make sure they will trip. Then leave them be and see if they trip. The past user would have them close enough to start with. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
