Corsicana Rotary Cutter
Ed wood
New User
We have used a Corsicana drag type rotary cutter since the 50's. We have other cutters but I still like to use the 5' cutter. The problem is I broke a U-Joint on the PTO shaft next to the gearbox. Does anyone know where I can find a new one.
Ed,
We had a similar situation on an old hay baler.
Factory part NLA.
What we did was take the old one to a local fabrication/machine shop and matched it up by size. There are also automotive u-joints that might work.Also there are online places that sell u-joints by size. Hope this helps.
Unfortunately the manufacturer for Corsicana rotary cutters is no longer in business.
You might try this <a href="http://www.powellequipmentparts.com/cutting-equipment-parts.cfm">supplier</a>.
You might also contact a drive shaft repair shop.
Thank you. I bought a new PTO shaft but it would not fit the gear box shaft. I think I will have to have new one put on
