Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: jd 336 timing
[Return to Forum]
rich o
08-20-2012 15:09:58
66.220.233.8
i beleive my john deer 336 string baler is out of time, both the main and needle shears bolts keep snapping. this just started happening as i started baling second cut. 3000 bales of first crop and it didnt even miss a knot. ive had timing issues with a nh baler and it seems to make sence that its the issue. i just dont have a manual for this unit. if anyone knows the proper timing ques pls post them up, i have lots of good hay down and cant afford to lose it. thanks very much
[Reply]   [No Email]
Northvale - PA
08-23-2012 19:42:01
71.114.135.247
Re: jd 336 timing in reply to rich o, 08-20-2012 15:09:58
earlier this season my 336 lower bale case tension rail rusted thru and broke at the pivot point. It pushed the needles out of the home position which in turn caused the flywheel shear bolt to break, which in turn stopped the kicker from kicking. Look underneath too. Make sure the needles are not obstructed from the home position.
  [Reply]  [No Email]
Tx Jim
08-23-2012 09:50:39
67.142.163.22
Re: jd 336 timing in reply to bison, 08-20-2012 15:09:58
A common reason for needles contacting bale-case channels or knotter system is getting wear at the pivot points of needle frame on either side of bale-case. Sometimes adding a washer with larger inside diameter than the needle frame bushing will cure the problem.
  [Reply]  [No Email]
Tx Jim
08-23-2012 09:34:51
67.142.163.22
Re: jd 336 timing in reply to Hogleg, 08-20-2012 15:09:58
I agree with you about needle touching bale case or knotter will not constitute re-timing. BUT a 336 has 2 chains. The main chain at the very frt right behind the clutch and the feeder fork chain.
  [Reply]  [No Email]
Tx Jim
08-23-2012 09:29:57
67.142.163.22
Re: jd 336 timing in reply to Dean in iowa, 08-20-2012 15:09:58
Checking the timing and re-timing aren't exactly the same thing. One can recheck timing without loosening/removing anything but re-timing one must loosen/change something.
  [Reply]  [No Email]
Tx Jim
08-21-2012 09:22:49
67.142.163.20
Re: jd 336 timing in reply to Texasmark1, 08-20-2012 15:09:58
Needle rubbing the bale case will not cause a JD 336 baler to require re-timing.
  [Reply]  [No Email]
ASG
08-23-2012 08:25:00
63.71.120.26
Re: jd 336 timing in reply to Tx Jim, 08-21-2012 09:22:49
The needle was rubbing the knotter assembly and shearing the bolt.
Most balers are still within acceptable, but are generally near the timing limits due to wear, etc. By the time you start checking the timing after you adjust needles with chamber empty, you could just as well retime the baler since it only takes 10 minutes; then you know that the baler is "timed".
  [Reply]  [No Email]
RodInNS
08-23-2012 09:31:07
216.118.158.123
Re: jd 336 timing in reply to ASG, 08-23-2012 08:25:00
I can see where needles hitting the knotter frame would shear the knotter drive shear bolt... but that would be a very uncommon thing to have happen. Needles don't just move unless their retaining bolts get loose and you should notice it with erratic ties long before anything else happens.
Most common cause of sheared bolts would be a bad needle brake.
I can't for the life of me see a need to retime a baler unless it's known to be out of time. One thing to run it through a cycle by hand to make sure it's roughly in time... but on a Deere it's not as likely to jump time as various others. It's got one chain and the rest is gears... so as long as the front chain hasn't fallen off I'd expect it to be in time.
Rod
  [Reply]  [No Email]
ASG
08-21-2012 08:08:37
63.71.120.26
I had a similar problem at the begining of the season with a 336 baler. The needles needed adjustment as they were rubbing the knotter assembly when they came up and the needle shear bolt would shear. Then the needles would not return home and would then shear main bolt.
Solution:
Clean out the bale chamber and check the need clearance to the knotter assembly. It is rubs, loosen one bolt on needle and tighten opposite to tilt the angle of the needle on the arm until it no longer rubs. Then retime the baler per serive manual instructions above.
  [Reply]  [No Email]
Tx Jim
08-21-2012 03:48:39
67.142.163.23
rich o
336/346 and newer balers only have 2 places to time(feeder fingers and PH to needles). Be sure frt chain idler sprocket is snug against the frt chain(often neglected from being mostly hide). If chain gets too much slack it can walk over teeth getting timing off. I have seen bolt(parts key #23) shear but regular shear pin(parts key #24) not shear and arm inadvertently replaced on needle lift shaft 180% off.
Also check needle brakes(parts key #13) for snugness as a worn/loose needle brake has caused many shear pins to be sheared.
This post was edited by Tx Jim at 03:51:22 08/21/12.
  [Reply]  [No Email]
JohnS1970
08-20-2012 19:05:25
74.15.240.239
Here are the pages from the manual for timing. I also posted the page that shows the measurements for the safety stop. Seems rather odd it started suddenly. Our 336 broke the knotter drive shear bolt this summer but I think it was age since I can't remember the last time I replaced it and it worked fine after replacement. Try turning everything over by hand through one tying cycle and see if something stands out. Let us know what you find.
  [Reply]  [No Email]
TomH in Pa
08-20-2012 15:25:10
67.235.10.94
Is the plunger hitting the dogs that protect the needles? If not I don't understand how it could be timing. Otherwise it sounds like something is adding a lot of resistance. Dull hay knife or plunger out of adjustment maybe?
  [Reply]  [No Email]
RodInNS
08-20-2012 15:16:42
216.118.158.123
There's only one chain to jump time on that thing and not much reason to think it would...
Check the plunger stop and other workings of the knotter and make sure they're all free... make sure the needle yolk returns home fully.. things like that. My 327 broke the knotter shear bolt last year and I forget just why at this point... but check around that area. Something will pop out at you.
Rod
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
