| Implement Alley Discussion Forum |
Topic: Vermeer 504G pulls tractor down hard...any suggestions?
[Return to Forum]
| Author |
[Modern View]
| Jason S.
08-17-2012 05:08:58
174.252.156.75
I"ve got a Vermeer 504G I pull with a 175 Massey Ferguson. I got both pieces from the same dealer and he is a Vermeer and Massey dealer. He said that tractor should have plenty of power for that baler but the baler pulls it down hard. The bale restrictors are no longer available for them is what they told me...I read a post on here where HayDR mentioned changing the main drive gear to a 10 tooth. Anybody have any other ideas? The tractor is fine pulling everything else I have. The bearings and chains in the baler are good also. Thanks for your help. |
| Hay DR
08-18-2012 21:31:42
76.7.168.29
Re: Vermeer 504G pulls tractor down hard...any suggestions? in reply to Jason S., 08-17-2012 05:08:58
| The stock drive gear is a 13 tooth. A 10 or 12 tooth gear is available from Motion Industries. I have customers with MF135 tractors runing the 504G balers. Your tractor should run this baler easy. If I had to guess what is wrong is the drum roller has a sheared SDS hub. There are 3 SDS hubs on the drum roller assembly. The parts is cheap but there is a bit of labor because you will have to drop the bottom drum roller out of the baler. Give your symptoms it’s either this or a top drive roller with a broken shaft. |
| Jason S.
08-20-2012 09:57:46
174.228.90.1
Re: Vermeer 504G pulls tractor down hard...any suggestions? in reply to Hay DR, 08-18-2012 21:31:42
| Is there anyway to diagnose if it"s a sheared SDS hub without taking the drum roller out? I"ve got the owners manual for this baler but do you know of a technical manual for it? I"ve put bearings on the rollers and even on the drive side of the drum roller but I have no clue what is involved on taking the drum roller out. I"m about to the point of just selling it for scrap because it is always giving me problems...I think the previous owners neglected it pretty hard |
| KEH
08-17-2012 14:37:13
209.213.30.15
| I had a 504F, with MF name on it and model number 1450. It was not difficult to pull at all. I could stop a full bale and restart it with no problems. Tractor had 64 hp.Is the baler hard to turn over when empty? If it turns ok empty, at what size bale does it start getting hard to pull? Are belts pulling to one side? Are the governors working ok on the tractor? Are the springs stretching out good if you force a bale through it? Are the arms the springs are attached to moving up and down properly, well lubricated? I'm really out of ideas and reaching sort of far out. KEH |
| Jason S.
08-17-2012 17:47:01
174.252.150.153
Re: Vermeer 504G pulls tractor down hard...any suggestions? in reply to KEH, 08-17-2012 14:37:13
| It turns over fine empty...it starts pulling the tractor down when it gets between half a bale and a full bale. The tractor runs fine...the governor is working on the tractor and the baler gives it a workout. Most of the Massey versions I have seen had the bale restrictors in them which helps a lot. But they are no longer available from Vermeer and neither is a 10 tooth main drive sprocket so I guess my only option left is to trade it off. |
| onefarmer
08-18-2012 15:58:45
184.21.168.206
Re: Vermeer 504G pulls tractor down hard...any suggestions? in reply to Jason S., 08-17-2012 17:47:01
| Seems like a competent machine shop could make the restrictors. |
| KEH
08-18-2012 14:21:19
209.213.30.15
| | Seems like some Vermeers need the bale restrictors and some don't. Is it packing the bales real tight and if so, can the bale tension be reduced? Possibly you could find a junk baler and get the bale restrictors off it. KEH |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
