| Implement Alley Discussion Forum |
Topic: Vermeer 605 MF 1560 baler plugging
[Return to Forum]
| Author |
[Modern View]
| Sask_Michael
08-16-2012 10:58:32
67.225.62.47
Bought a MF 1560 baler last fall, so this is first time for me running it (or any baler). I made one bale, and it worked really well. On the second one, the pickup stopped turning, and I discovered I had a broken hub on the large sprocked that turns the ribbed drum/belt drive for pickup shaft. It had a previous weld that gave way.However, in pulling out the small core I started, I discovered the reason for the hub breaking was likely because there was hay stuffed between the steel ribbed drum and the square tube cross brace located a couple inches away. It was plugged so tight it took an hour to get the hay out. I noticed that the steel roller has a large dent in it, and I am wondering if the large gap between the drum and the square tube is the reason for hay getting in there and jamming it up. If so, should it be patched with some iron welded in? |
| Kelly MT
08-17-2012 07:28:50
216.14.251.158
Re: Vermeer 605 MF 1560 baler plugging in reply to Sask_Michael, 08-16-2012 10:58:32
| My 605H needs a little extra pressure now and then to latch the gate. Make sure the latch indicator shows latch. PK |
| Brandonh
08-16-2012 19:50:18
69.55.119.129
| the reason it jammed between the drum and that square bar is because your tailgate didnt latch properly. Be sure when you dump the bale and close the gate that it latches properly. Sometimes you have to hold a little pressure on the gate when it closes for it to latch. Just keep the lever down a little longer. Also may need to grease the latches. Had the same thing happen on my 504f and its a pain to get that hay out!! |
| Sask_Michael
09-27-2012 21:43:24
207.47.177.2
Re: Vermeer 605 MF 1560 baler plugging in reply to Brandonh, 08-16-2012 19:50:18
| | Thanks for the posts. I have been able to roll up some decent bales since without the same problem. However I have a new problem now: not all the hay is going into the chamber from the pickup. A lot of it is getting shredded and kicked out in front of the pickup. After I make a bale, there is a trail of shredded hay left behind. The stuff I am baling right now is extremely dry, and I was wondering if that has anything to do with it. I am only going in 1st gear, so too fast can"t be why. |
| Sask_Michael
09-29-2012 22:36:59
207.47.177.2
Re: Vermeer 605 MF 1560 baler plugging in reply to Sask_Michael, 09-27-2012 21:43:24
| | Figured out this problem as well...cutting grass that was cut too short. It was like chaff. Anyone know how wide the feeder roller rubber strips are supposed to be? Was gonna replace them, as they seem to be very worn and short. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
