Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: New Holland 268
[Return to Forum]
Wilberton
08-06-2012 19:32:01
38.104.162.74
Look what followed me home Saturday. A New Holland 268 Hayliner. Got it real reasonable. The guy I got it off of said they went to big round bales 12 years ago and parked it in the shed. It was bought new by his uncle. He loaned me some wheels and tires to get it home with. Pulled it 60 miles home.
Starting to clean it up and grease it up. Any advise is welcome.
[Reply]   [No Email]
strikefalcon
08-08-2012 19:06:41
184.20.100.20
 Re: New Holland 268 in reply to Wilberton, 08-06-2012 19:32:01
Got my 268 this spring. It had sat outside for at least 5years. Greased and oiled her up and put it to work. sheared 4 bolts on the first two bales until the rust scrubbed off, Then ran the next 1400 bales on 3 bolts. missed two ties the whole time. Yours looks in better shape too.
[Reply]  [No Email]
Diydave
08-07-2012 15:42:11
96.244.160.31
I sold one about a month ago. It was a good baler, but kinda the same story. Parked it when I got the round baler!
[Reply]  [No Email]
Gumby
08-07-2012 10:29:22
64.6.8.35
Be sure to get a manual. When going through the knotters, follow the instructions in than manual precisely. I finally got the knotters on my NH 273 tweaked, but I had to pay close attention to all the adjustments. It bales like a champ now.
[Reply]  [No Email]
Brian in MA
08-07-2012 05:14:18
70.91.218.113
Good balers, I love mine. I'm always trying to find another one reasonably priced for a spare. I have replaced some bearings over the years, had the knotter rebuilt a few years back and it's a dream to use.
[Reply]  [No Email]
LincolnIA
08-06-2012 20:20:38
70.198.0.159
My 268 looks like it it should have went to scrap 20 years ago but it wont die. I still do about 2500 bales a year with it. I have a bent pick up bar that ruins a bearing once a year but that is the only problem I have ever had with it. I will send you a copy of the manual if you are interested.
[Reply]  [No Email]
Wilberton
08-06-2012 20:42:41
38.104.162.74
 Re: New Holland 268 in reply to LincolnIA, 08-06-2012 20:20:38
LincolnIA
I would be very interested in a manual. Let me know what you need.
[Reply]  [No Email]
parisspringstom
08-06-2012 20:10:09
67.223.202.30
I have used one for last 5 or 6 years. Feeds alot faster than my old international baler.
[Reply]  [No Email]
RayP(MI)
08-06-2012 19:53:56
207.241.137.116
Have a lot of experience with a 268. They're a good sound baler. You may need to adjust feed forks entry into bale chamber to reduce/prevent banana bales. You cannot correct banana bales by changing the pressure cranks on the rear of cahmber. They will just control bale density. Probably not good to make bales too dense. Also helps to keep a smooth flow of hay into pickup. Yes you can over load them, but they have a whole lot of capacity. Make sure hay dogs are in working condition, springs not broken. Keep areas around hay dogs clean. I have 6 restrictors on the bale chamber, 3 on each side. Make sure yours are in good condition. Knotters are much like most brands, can be contankerous. Keep them clean, greased, properly adjusted. GET A MANUAL, available from NH, and various on line sources. Very valuble information.
[Reply]  [No Email]
G Campbell
08-07-2012 07:17:30
71.169.107.207
 Re: New Holland 268 in reply to RayP(MI), 08-06-2012 19:53:56
I have rarely been able to make a square bale - they are as you call them 'banana' bales, that fall apart when handled - even carefully. We have replaced many parts in the effort to solve this problem, on the advice of our NH dealer.
I have lost the owners manual - should say mis placed it and would like to obtain another, but not sure how to go about it. This is about as technical as I get with a pc....and this took me a long timeto get to!
Any help would be greatly appreciated.
Thank you.
[Reply]  [No Email]
rusty6
08-07-2012 07:35:03
142.165.85.183
 Re: New Holland 268 in reply to G Campbell, 08-07-2012 07:17:30
I ran a 270 NH for years and it was a decent baler but you could not push it too hard or knots would hang on the billhook and break. Eventually wear and tear took out the forks that carry the hay to the plunger. I had a MF 120 in reserve to parked the New Holland.
I think the hay stops in the bale chamber are a big help in eliminating banana bales on New Holland.
[URL=http://good-times.webshots.com/photo/2397054220032927439LSkagT][/URL]
[Reply]  [No Email]
Wilberton
08-06-2012 20:46:26
38.104.162.74
From what I can see the rear pair of feed forks has one broken off, since there is only one there now. The forward two forks are longer and go about half-way into the bale chamber when fully extended.
[Reply]  [No Email]
RayP(MI)
08-07-2012 05:08:31
207.241.137.116
 Re: New Holland 268 in reply to Wilberton, 08-06-2012 20:46:26
You can make new ones out of ALUMINUM rod, available at most metal venders. Make sure to get the right diameter, as there are two different diameters. For the pointy end, just saw it off at an angle, and it will wear pointy fairly quickly. Be sure to use ALUMINUM. If they break off and go through the knife, you want to have something that doesn't damage the knife. And yes, I've found severed fork pieces in the baled hay. Most probably can get them from NH dealer as well, just add $. So far, most parts I've needed are available. Most in stock. Knotters and parts are common to several NH balers.
[Reply]  [No Email]
1130Leo
08-07-2012 05:44:32
12.188.165.254
 Re: New Holland 268 in reply to RayP(MI), 08-07-2012 05:08:31
I saw one of these go at an auction last weekend, it seemed to be in decent condition, fresh paint, missing the outer shield, but rolled over easily and seemed to be tight. It sold for $150.00. If I had been close enough I would have bought it as a backup baler, which is why I stayed a long way from the equipment line while they were selling, I do not really need another baler...
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
