Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Ford 530 Used Parts
[Return to Forum]
rwskinner
08-02-2012 17:33:29
12.52.88.13
I'm looking for some used Ford 530 parts in decent shape.
I need some of the leaf springs for the flywheel clutch. I also was wondering if there is another source for clutch disc other than New Holland. My small disc for the PTO shaft are history. The larger ones for the flywheel look pretty decent.
Thanks,
Richard
[Reply]   [No Email]
RodInNS
08-02-2012 18:21:07
216.118.158.123
 Re: Ford 530 Used Parts in reply to rwskinner, 08-02-2012 17:33:29
The discs aren't that bad from NH... though you could probably match them up with weasler aftermarket stuff if someone keeps a good rack of it on hand.
The springs... I just used coil springs on mine. IIRC I actually got a larger spring and a smaller spring to fit inside it... cut them mabey 2.5" long... flat washer and lock nuts, new bolts, etc... then wind them down fairly tight. It will take some adjusting to get it tight enough. Also get HEAVY springs with 3/16" or so coils if you can. I used lighter and it's not quite as strong as I'd like but it does work. Probably needs a bit more adjusting yet too...
Rod
[Reply]  [No Email]
rwskinner
08-02-2012 18:50:50
12.52.88.13
 Re: Ford 530 Used Parts in reply to RodInNS, 08-02-2012 18:21:07
I ordered everything from Messicks. I thought everything was "fairly" reasonable except those dang springs. I have a stack of clutch springs out of a 1650 Oliver that would most likely work. If they are good enough for a 70hp tractor they shouldn't be too weak for the old baler. I'd be running three instead of the 6 the 1650D had.
The last time I baled my grass was thin and the windrows were light and I just couldn't get very many good bales.
This time, the windrows were nice and thick and this sucker made very nice uniform bales, only at 2 mph. Anything faster caused it to clog under the wind guard or slip the clutch when it made it to the chamber.
I had to back off the tension because the bales were 90# and the string would pop as soon as they hit the ground.
I'm actually pretty impressed for a baler that hadn't done anything for 20 years but sit in a barn.
Richard
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
