| Implement Alley Discussion Forum |
Topic: NH Super 66 4H project udpate
[Return to Forum]
| Author |
[Modern View]
| JRSutton
07-31-2012 05:23:09
75.130.109.233
 We finally got most of the bees, mice, and snakes out of the donated baler. (it sat untouched for 15 years) So we're getting into it now. First on our agenda was to see if the engine would run well enough to test the bailer out before doing a rebuild. It turned over, but no sign of life at all. We pressure washed the engine so we could see it better - released a stuck exhaust valve - cleaned out the gas tank - blew out the gas lines - removed the carb and gave it a good cleaning - filed the points flat so they worked again, put in a new condensor - cleaned up the fouled plugs - got spark - hooked up temporary gravity fed fuel line - put fresh oil in. Hooked up the starter to a car battery (what a great option the starter is to have!) Took a few tries to get the starter to engage, but the bendix finally broke free and engaged the engine. A little starting fluid and a few minutes of cranking and we started getting some sputtering. A little more - and we had her purring like a kitten - if you can call that noise a purr. After running for a few minutes, the fuel pump started pumping gas. Burns some oil - but we expected that. It'll need a rebuild, but so far I'm thinking it's running strong enough to get through this season. Next step is to manually cylcle the baler and check the timing on everything - check all the components inside - etc. |
| Jimmy in Indiana
08-01-2012 10:56:53
208.88.251.99
Re: NH Super 66 4H project udpate in reply to JRSutton, 07-31-2012 05:23:09
| Does anyone know the difference between a super 66 and just a regular 66? |
| JRSutton
08-01-2012 11:42:26
75.130.109.233
Re: NH Super 66 4H project udpate in reply to Jimmy in Indiana, 08-01-2012 10:56:53
| I asked that same question a while ago - can't remember all the answers, but I believe the biggest thing was the wheel bearings were heavier duty on the super. |
| Leroy
08-01-2012 18:14:04
69.88.205.38
Re: NH Super 66 4H project udpate in reply to JRSutton, 08-01-2012 11:42:26
| I will have to go out and check but I do not remember any difference in them at all. The biggest difference is the way they measure the bale length, then there is supposedly a difference in the pickup but I did not see that, all I have left is the axles as I thought I might have use for them. |
| JRSutton
08-02-2012 08:04:08
75.130.109.233
Re: NH Super 66 4H project udpate in reply to Leroy, 08-01-2012 18:14:04
| | hey leroy - any luck finding a spare needle? We've got the baler cycling through completely now - manualy. The big U-shaped arm the needles mount to is cracked pretty badly - but once we get that welded up - we're pretty much ready to do a test run baling some hay. The engine's running good - we'er anxious to pull that lever on the idler pulley to see what happens. Throw some hay into it and see what comes out the other end. But we're dead in the water with only one needle! I've been searching around locally, haven't found anything yet. |
| JRSutton
08-02-2012 08:00:23
75.130.109.233
| | yes - that's true - the supers could do smaller bails - down to 12". The regular 66 had fewer bale length options - So- a pretty insignificant difference in my opinion. |
| Jim in Ma.
07-31-2012 16:05:21
72.70.109.209
| I run a NH #69 with an engine like that. It was always hard to start, so I added one of those pump bulbs like thay use on out board motors. With 3 or 4 pumps of that it starts rite up. Sounds like a great project for them. |
| JRSutton
08-01-2012 11:41:21
75.130.109.233
Re: NH Super 66 4H project udpate in reply to Jim in Ma., 07-31-2012 16:05:21
| | interesting - I"ll keep that in mind. right now it"s starting on the third or fourth try (without the starter). But once we start using it - I"m thinking I"ll probably rely on the electric starter most of the time anyways. We"ll see how it goes. thanks for the idea - |
| Wendell Parsons
07-31-2012 11:38:19
69.129.148.194
| Wow, that brings back memories...dad had a 2 cyl Wisconsin, hand start. Starting hot was a bugger. We would put a rope on the wheel and pull. Faithful engine and baler, would have loved to know how many bales went thru that machine...What a great project |
| tomturkey
07-31-2012 11:22:41
216.81.211.253
| Looks like an outstanding learning opportunity for all involved. Take lots of pictures and then sort out the best for the project note book. I will enjoy viewing it when completed. I think I see purple in your future. gobble |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
