Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: john deere 10a hammermill
[Return to Forum]
Ron B in ohio
07-28-2012 05:36:04
66.102.63.244
I bought a JD 10A Hammermill, PTO driven, the issue is proper rotation. The wear on the teeth in the mill suggests that the hammerteeth force the feed down into the mill as it is fed into the mill. I am powering it with a Ford 801, PTO rotation clockwise as you look at it (I don"t know of any other rotation for a tactor??). This makes the mill run so it tries to throw the feed up over the top of the mill. I have not tried to run feed through it yet so I don"t know if it works or not the way it is. ????
[Reply]   [No Email]
onefarmer
07-28-2012 20:15:56
66.87.4.44
Re: john deere 10a hammermill in reply to Ron B in ohio, 07-28-2012 05:36:04
Here is a parts book for the JD 10a.
We also had one for years when I was a kid. Looking at the pulley the shaft would spin CCW This would also spin it correctly for the blower. It would lift up on the material as it entered because the way it is designed it blow out the door if it was to grind downward. And the chute was on the right as you looked at the pulley.
  [Reply]  [No Email]
Ron B in ohio
07-28-2012 11:12:11
66.102.63.244
Thanks all, I have not run any feed through it yet. The machine fan does blow "out" like it is supposed to with some force and also rotates CCW as you face the PTO pullys, however the teeth of the hammermill are coming "up" against the feed as it enters the mill. I will look more closely at it, perhaps it does have an aftermarket PTO adaptor on it. It worked for the previous owner fine, just spit grain at him a little(as stated by tractor 300). Now then, does anyone know a quick way to build a set of gears to get it to run clockwise??
  [Reply]  [No Email]
Cienna
07-28-2012 13:21:23
50.96.7.142
Re: john deere 10a hammermill in reply to Ron B in ohio, 07-28-2012 11:12:11
Trying to think of possibilities here----#1--Is there such a thing as a H-mill that has the feeder trough to the RIGHT, rather than to the LEFT, as you look at the HM from the PTO side? That would account for the hammers to come "upward" as the grain is fed into the mill. #2--If the concave is rotating incorrectly, but the blower is functioning as it should---then maybe the fan belt is twisted one-half turn, when it wasn't intended to work that way. Interesting circumstances !!!
  [Reply]  [No Email]
rrlund
07-28-2012 15:00:56
207.241.137.116
Re: john deere 10a hammermill in reply to Cienna, 07-28-2012 13:21:23
The one I had had about 5 or 6 V belts on it. Turned the same way as the PTO,hammers came up instead of down,fed on the left as you're standing behind it instead of the right like all grinder mixers. I worked,I used it for a lot of years,I just always knew it seemed odd that it ran the way it did. Just seemed like whoever designed the PTO adapter didn't really think it through.
  [Reply]  [No Email]
430WLPG
07-28-2012 07:10:06
166.181.3.214
Those teeth are reverseable so you can get twice the life to wear ,someone may have reversed them and never used it again
  [Reply]  [No Email]
rrlund
07-28-2012 06:37:30
207.241.137.116
I had one with what looked like a Deere PTO adapter on it. It looked to me like it ran the wrong way,but the blower on the back of it worked and you'd have thought if it wasn't blowing the feed out that would indicate it was running the wrong way. Don't know,just know it worked.
  [Reply]  [No Email]
buickanddeere
07-28-2012 07:34:31
184.151.61.6
Re: john deere 10a hammermill in reply to rrlund, 07-28-2012 06:37:30
Centrifugal fan so it may function to a degree in reverse.
Rotation has the hammers forcing to feed down against the shear bar that holds the screen in place iirc.
CCW facing the main shaft where the drive pulley(s)is/are.
  [Reply]  [No Email]
tractor300
07-28-2012 06:24:44
74.36.163.136
Is this a factory PTO setup or an aftermarket? Year's ago I had a 10A with an aftermarket PTO setup and it worked proper with grain going down to screen. Good mill, ground a lot of feed with it, more than I care to remember. Check the rotation again, if it is throwing the grain up and around it would probably be spitting part of it back out the grain chute.
  [Reply]  [No Email]
Cienna
07-28-2012 06:23:27
50.96.7.142
If the PTO on your tractor is CW (as you look at it from the rear), then the hammermill would turn CCW (as you face the HM from the PTO side). This SHOULD be the correct rotation. The rotation should be such that as the grain enters the mill, the hammers force the grain downward towards the screen.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
