Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: kuhn fc4000rg or deutz allis sm60rc
[Return to Forum]
steve in wi
07-27-2012 12:36:33
166.249.130.31
I,am looking at a deutz all is sm60rc disc mower,does anyone know who made it for them.also has any one every used one and how they liked it. Also I came across a Kuhn fc4000rg discbine,that needs work, it only 3 gs so I am assuming it needs work,question has anyone used a Kuhn 4000 and will a 706 diesel handle that machine.if anyone has any pros or cons on either machine I would like to hear them so I have something to ask when i go look at theses machines.thanks Steve
[Reply]   [No Email]
steve in wi
07-27-2012 12:44:57
166.249.130.31
Re: kuhn fc4000rg or deutz allis sm60rc in reply to steve in wi, 07-27-2012 12:36:33
I forgot the da is 1998 model,its cheap,but maybe theirs a reason.
  [Reply]  [No Email]
KEH
07-27-2012 15:10:13
209.213.31.66
Re: kuhn fc4000rg or deutz allis sm60rc in reply to steve in wi, 07-27-2012 12:44:57
A few years ago i did some work for a Kuhn dealer assembling disc MCs, but I don't remember the model numbers. They were well built machines, my immediate opinion which well could be wrong was that they were too complicated.
Is the one you are looking a roller conditioner or does it have impellers? The dealer had a roller one in the shop that had a bracket fail on the RH side of one of the rolls. It worked up and down in a slot to adjust as the volume of hay changed and failed because it was cast iron instead of steel fabrication or a steel forging, so I would check that.
Another one came in with a bad cutterbar assembly because the owner had filled the cutterbar too full of oil. It developed too much pressure and ruined gears. It was cheaper to buy a new cutterbar than to rebuild it. The factory rep said disc mowers lasted better a little low on oil rather than overfilled.
Basically, what you should do is hear the thing run, preferrably see it cut hay but I know that's probably impossible. If a Kuhn dealer has it you can ask more about its history.
Oh, there's a couple of gear boxes on the LH side of the machine, under the sheet metal. You can check them for leaks, low oil, excessive noise.
There's supposed to be 2 wheel blocks made of galvanized steel carried in brackets on the back of the machine. Probably gone by now.
I don't know if the 706 would pull it or not. I think the dealer said a 10 footer needed 70 hp to handle it, but I could be wrong. Some of those machines needed 2 sets of remotes, one to raise and lower the cutterbar, the other to swing the tongue over.
KEH
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
