Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: New Holland 270
[Return to Forum]
Martell
07-21-2012 08:29:12
166.147.120.20
I just purchased a New Holland 270 square baler the sales man swore that he watched it work perfect at the time it was traded in. I hooked it to the tractor upon receiving it and it doesn't pick up the hay what should I do?
[Reply]   [No Email]
MLD
07-23-2012 12:00:53
206.125.176.5
Re: New Holland 270 in reply to Martell, 07-21-2012 08:29:12
I'd go back to the salesman.
  [Reply]  [No Email]
chevytaHOE5674
07-21-2012 15:28:20
74.221.61.254
Chances are the slip clutch for the pickup is slipping. Get a manual and parts book and dismantle/clean it up and reassemble and tighten it down to manufactures specs and give it a try.
  [Reply]  [No Email]
GordoSD
07-21-2012 12:40:15
64.33.250.162
Where do you have the gauge wheel set. Are the rake teeth hitting the ground?
There is a slip clutch for the pickup. Watch that and see if it is engaged. If not Disassemble that clean and replace then adjust to proper tension.
  [Reply]  [No Email]
old
07-21-2012 08:52:42
209.86.226.19
Well #1 I would ask the dealer you got it from since you said he said so it should be as said. As for it not working #2 order the owners/op. manual for it. #3 how long did it sit in the dealers lot?? Could be as simple as rusty chains and parts that have froze up form lack of lube and good old time sitting in one place. Hook it up and with the tractor running at a low idle kick the PTO in then take a walk around and find where what is not moving. Put your hands in your pockets and keep them there when you do this so you will keep all 10 fingers. When you see where things stop shut the PTO and the tractor off and work on the chains etc that are causing the problem
  [Reply]  [No Email]
Tim(nj)
07-21-2012 08:46:05
67.237.10.99
when you say it doesn't pick up the hay, what exactly is it doing or not doing?
  [Reply]  [No Email]
Martell
07-21-2012 08:54:40
166.147.120.22
Re: New Holland 270 in reply to Tim(nj), 07-21-2012 08:46:05
The rake part doesn't turn at all
  [Reply]  [No Email]
rrlund
07-21-2012 09:00:03
207.241.137.116
Re: New Holland 270 in reply to Martell, 07-21-2012 08:54:40
Not familiar with that model,but when I got the pickup head for my CASEIH chopper out of the shed a few years ago,the auger worked but the pickup didn't. There are dogs in that one that allow the bars in the pickup to turn backwards when it isn't running. I'm thinking there's probably some similar setup in that baler.
Turn it backwards and look at the point where things are turning meets up to what isn't. I'm guessing something is just rusted up or has enough dried grease in it to be the place where the problem is.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
