| Implement Alley Discussion Forum |
Topic: J D 14 T baler
[Return to Forum]
| Author |
[Modern View]
| Irv Plitzuweit
06-27-2012 18:24:44
71.55.132.130
We are using an old John Deere 14 T Baler at an Historic Farm in S E Minnesota. We have just odered a manual, but before it arrives I would solicit advice about the one problem we have with the baler. Some times it makes double size bales as the lever on the left side of the knotters doesn't quite go over "dead center" so when the spiked wheel tell it to trip, it doesn't. We thought we had the answer to always run at full 540 PTO rpm, and that helps, but does not fully fix the problem. Any thoughts on adjustment that may help will be appreciated. |
| Tx Jim
06-28-2012 03:37:49
67.142.163.24
Re: J D 14 T baler in reply to low budget, 06-27-2012 18:24:44
| 14T's had 2 different style measuring wheels. Is the baler in question above or below SN 58334. Actually there's no lever(apparatus) on LH side that controls bale length. Length control mechanism is on RH(passengers) side. This mechanism sometimes isn't properly resetting itself after the knotter cycles. |
| tjdub
06-27-2012 23:19:39
208.74.246.137
Re: J D 14 T baler in reply to Irv Plitzuweit, 06-27-2012 18:24:44
| | I have a 24T and it has made many of these "double bales" in it's life, but it hasn't made one it at least 2 years, so it can't all be due to wear. For me, it only happens when baling wet hay (which probably shouldn't have been square baled anyway). I don't know the true cause of the problem, but when baling good hay, it never happens. Anyway, if you watch the arm closely when you're feeding hay in, you should be able to see what happens when it trips (or is supposed to trip). Maybe something on that arm is just a little rusted and needs a finger-full of grease, or maybe it needs some weld built up and then ground down, but you should be able to tell if it "trips" and doesn't send the tiers in motion. Just turn the PTO off and give the arm an extra pull up and watch to see what the "snag" is. |
| old
06-27-2012 18:56:18
209.86.226.59
| The manual does not address that problem as such but it could be that your windrows are to small so as not to have enough hay being feed in or your ground speed it to slow. Hay dogs not holding as they should could also play a part in your problem But as I said the manual does not really address that as such I know I just looked in the one I have here on my desk |
| jdv
06-27-2012 18:31:17
67.209.221.197
| on the newholland if memory serves there was a spring that held it tight so it didnt slip not sure on a jd though |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
