Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: New Holland 489
[Return to Forum]
meadowland
06-19-2012 20:06:07
67.85.52.216
We have a new holland 489 haybine that keep jamming. as soon as it gets into hay the bar and real will stop working and act like they are plugging up. as soon as you lift the head and pull out some of the hay it will begin to move again until you try and put more hay through it. any ideas?
[Reply]   [No Email]
onefarmer
06-20-2012 11:50:10
66.87.2.147
 Re: New Holland 489 in reply to meadowland, 06-19-2012 20:06:07
I'm betting loose drive belt. The one that goes from the gear box forward to run the drive shaft that goes across to the cutter bar drive. The reel is driven off the cutter bar drive to, so if the belt slips the cutter and the reel would both stop.
[Reply]  [No Email]
Longmeadow Farm
06-20-2012 04:49:54
74.76.6.244
You could have a number of problems, which is dependant on the type grass you're trying to cut and the type cutterbar used... standard guards vs no-plug guards. If the grass is low to the ground thick stuff you may need to check your knives, drive belt tension and reel timing. Most Haybines are set up for "normal" conditions. The low short stuff may require some "adjustments". I remember those days trying to get a haybine into heavy clover and rye grass...and concluded that if I was bound and determined to grow that stuff, I needed to spend additional time setting up the machine for the crop conditions.. or buying a disk mower conditioner... I opted for the latter.
[Reply]  [No Email]
Ken Macfarlane
06-20-2012 04:04:26
184.151.114.56
If the main belt is tight and you still have trouble it may be the guards and knives have too much clearance and are wedging hay.
[Reply]  [No Email]
JDseller
06-19-2012 23:11:49
208.126.196.144
I would bet loose drive belts. They will drive under no load but slip as soon as you hit the hay. Check the drive belts out. The reel drive is on the right side and the cutter bar on the left.
Also IS the main slip clutch slipping??? Does the rolls stop when the head plugs up??? If it doe then the main slip clutch is slipping.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
