Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: compression pick-up 24t
[Return to Forum]
Finnbair2020
06-19-2012 06:27:07
64.223.158.144
I have a Jd 24t baler-- works well. The parts baler I have has a windrow compressor on it. I was thinking of putting it on the baler I use. Is it worth the time? Has anyone used this model of baler with the compressor on the pickup? Much benefit?
[Reply]   [No Email]
JDseller
06-19-2012 23:00:23
208.126.196.144
 Re: compression pick-up 24t in reply to Finnbair2020, 06-19-2012 06:27:07
In light hay the one you are talking about will help. In big windrows it will be in the way. So you decide which you have to bale the most of, big or small windrows.
[Reply]  [No Email]
James22
06-19-2012 11:02:01
207.179.221.113
Had the original bar with spring down pressure setup on the 24T, but it was tough to pick-up straw that went thru a rotary. Considered the next upgrade, but decided to go all-the-way and bought the flatbar package that makes the pickup look like an old hay loader. Works great with standard/light windrows, but certainly would restrict too much if desiring maximum capacity. Probably the middle arrangement would be the best compromise.
[Reply]  [No Email]
Tx Jim
06-19-2012 09:18:08
67.142.163.24
 Re: compression pick-up 24t in reply to Matt in Mich, 06-19-2012 06:27:07
All JD sq balers were designed to have a compression rack. The rack helps hay feed into chamber better.
[Reply]  [No Email]
Finnbair2020
06-19-2012 10:01:26
64.223.158.144
 Re: compression pick-up 24t in reply to Tx Jim, 06-19-2012 09:18:08
Right-- I was unclear. The one I use has I think the standard rack-- straight bars horizontal to the ground. The parts baler I have has a curved compression rack that reaches down to the ground and looks like it would compress more. Just didn't know if it would make all that much difference. I often bale quite thick grass.
[Reply]  [No Email]
tomstractorsandtoys1
06-19-2012 12:37:34
64.136.27.228
 Re: compression pick-up 24t in reply to Finnbair2020, 06-19-2012 10:01:26
In fine grass, alfalfa and straw the compresser helps pick up more hay than the strait bars.It can restict feeding a little in big windrows of long grass.All 336 balers and newer had compressers.We put one on our 24T and would not go back.Yesterday I baled 1040 bales of straw and only had two untied bales when switching twine(my problem not tieing twine balls correctly) not bad for a 24T.
[Reply]  [No Email]
showcrop
06-19-2012 10:31:36
75.67.231.80
I have seen those. In average hay I think that they would be in the way. In light hay and second cut with little stem, I bet they would reduce the tendency of the hay to roll ahead of the pick up.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
