1010 New Holland Stacker
1130Leo
I had an issue with my Stacker not wanting to dump or lower the Load Table. I finally figured out the problem last night. The valve was stuck on the cylinder that controls the Load Tines on the Load Table. The Load Table would lift, but very very slowly, if I moved the 2nd Table a little bit the Load Table would move normally for a few inches, then slow down. Once I found this trick it clued me in that there was either a restriction or stuck valve. Just thought I"d post what I found so others that have this problem may find the fix much easier than I did.
