Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
John Deere G and 822 plow pictures
naylorbros
02-17-2012 13:31:44
Here are a few pictures of my John Deere G with a 822 rollover plow on it. I am still looking for parts for these plows. If you have extra parts please let me know.
Thanks
Ken
El Toro
02-18-2012 07:22:37
 Re: John Deere G and 822 plow pictures in reply to naylorbros, 02-17-2012 13:31:44
Use the Advanced Posting Tools for posting your pictures one or several. Hal
PS: Click on Upload Photo then on
Browse and select pic then on
Save then on Upload Photo then on Continue once for a second pic go back to Browse & select another pic click on Save then on Upload Photo & on Continue once
Click on Preview Your Reply and both pics should appear with your message.
wijim
02-17-2012 19:19:22
What kind of three point is on there? And how do the hydraulics work?Jim
naylorbros
02-18-2012 08:28:16
 Re: John Deere G and 822 plow pictures in reply to wijim, 02-17-2012 19:19:22
HI!! The three point is the standard Deere 801 hitch. The G has a JD live hydraulic pump on it with the valve that Deere supplied with the plow plumbed in the the pressure line off of the hydraulic pump. These plows were made to fit onto the first numbered series and the instruction book gives directions on how to cut the steel hydraulic line on these tractor and add the valve for the roll over cylinders. This conversion can be done with a normal single spool valve also and it works just as well. When the JD supplied valve on my 70 went bad the owners went and got a single spool valve form the supply store and simply replace the JD supplied valve. I am glad they kept the JD supplied valve because that is the one I fixed and put on the G. I would love to find a couple more of them.
Thanks
Ken
wijim
02-18-2012 09:36:13
 Re: John Deere G and 822 plow pictures in reply to naylorbros, 02-18-2012 08:28:16
I would like to find the whole setup like that for my 70D. Jim
naylorbros
02-18-2012 11:15:15
 Re: John Deere G and 822 plow pictures in reply to wijim, 02-18-2012 09:36:13
This plow came with my 70D. It is the 14" bottom version. I am putting a 16" bottom version together for the 70 and will keep the 14" for the G.
DeltaRed
02-17-2012 15:24:02
I had one of those once.Pulled it with the Super M.
naylorbros
02-17-2012 13:39:12
One more looking back at the plow working. Yes there are a few corn stocks caught on the rear standard. I need to play with the coulters some more. How can you add more than one picture per post?
Thanks
Ken
Dave Sherburne NY
02-17-2012 15:50:50
 Re: John Deere G and 822 plow pictures in reply to naylorbros, 02-17-2012 13:39:12
On the line that says OPTIONAL IMAGE URL just put a comma between each url. As for putting words under each picture, I have no idea.
El Toro
02-18-2012 08:14:24
 Re: John Deere G and 822 plow pictures in reply to Dave Sherburne NY, 02-17-2012 15:50:50
I put that writing in bold letters. Hope you can read it better. Hal
El Toro
02-18-2012 07:30:57
You use HTML writing to post pictures with a message beneath the picture. These symbols and punctuation tell the computer where to place your message below each picture. Hal
naylorbros
02-17-2012 13:35:25
I will try for a couple of more pictures. The next one is of an 820 with some 822 parts for you have a better idea of what they look like.
