Farmall CUB Equipment Auction Prices
68rs327
I am looking for some Equipment for my Farmall Cub. I was wondering what the auction prices are on the following items. A few auctions coming up around me soon with some Cub Equipment. Didn"t want to pay to much. Most is typical condition, a few barn kept and a few left outside. All are complete, just rusty. All Bolt on Equipment.
All in Fair Condition: In Kentucky: Auction Price
4" Disc-
Plow-
Cycle Mower-
Belly Mower-
Grader Blade-
Cultivators-
with my cub, ive got the plow, the front grader/snow blade, which with the proper brackets will also mid mount too, and a belly mower, for it, cub impliments go for more than 3 point impliments do, because they are all unique to the cub, also when looking at cub impliments it is very important that the mounting stuff is present with the impliments, or life is going to be hard, ie for the plow, you mush also have the handle that mounts to the right of the seat, and the brackets and dogbone that mount to the drawbar, [ you must have that too if yours doesnt already have one] for the belly mower, you also need the belt drive pully for the pto, as well as the mule drive setup which replaces the factory drawbar
Found a cycle mower locally for $100. But is pretty rusty from 40 years sitting outside and pitman arm gone.
The implements even get rusty when sheltered when the paint is worn off if you live where the humidity is high. The former owner of this plow and disk should've smeared some used engine oil or grease on the moldboard and landslide to keep it shiny. It will remove all that rust when its used for plowing. Hal
A pitman arm is under $ 20.
I got one that was rusty, It didn't to well and pluged up for the first 5 or 6 hours of use. Once things gor shined from use it turned out to be a pretty good little mower.
Pitman Arms are cheap, TSC use to sell them.
The mower I found was locked up tight. Been sitting in the dirt and mud outside for 40 plus years. Maybe with a Lot of sandblasting and I mean a Lot of blasting it might come back to life?
Not far from Bardstown, Ky.
Looking for Cub Equipment, do you know of any for sale in Ky.?
Wanted to find a few pieces to show and play with.
Around here,Cub accessorys are rare.So if you want them,you better buy them,regardless of price.You may not find any more soon....if ever.The guys who say"I dont want pay too much"usually never buy anything,because its always "too much".You need to get that notion out of your head.
As DeltaRed says if what you want buy at any price because ever finding anouther piece you can never count on. The only thing that would possibly not be in that class would be an after market brand rotary belly mower as I think those are being made new yet.
