timing a 269 NH hay baler
They need to be all the way in home but that's only the tip of the iceberg.The plugger has to be at TDC,metering wheel against the stop.You'll be ahead of the game if you get a book.It's easier to understand if you can read and see the steps.
Yes, and don"t forget that the chisel marks on the knotter clutch and pawl need to line up, too. Get a manual, well worth the $10-20.
(quoted from post at 22:40:38 11/22/11) They need to be all the way in home but that's only the tip of the iceberg.The plugger has to be at TDC,metering wheel against the stop.You'll be ahead of the game if you get a book.It's easier to understand if you can read and see the steps.
Charlie
If feeder teeth are timed correctly then can't the needles just be timed to the plungerhead without going through the complete timing?
I know that will work on a JD baler but I've only timed a very few NH balers.
That was one of the exercises the had us do at the Penn State FFA Mechanics skills contest in 1970. Some of the kids had a heck of a time but we had a New Holland baler at home. Yes, if you can see the procedure laid out it's not all that hard.
There was a post a few months ago with a video link attached. I think I saved it on my personal computer at home. If you'd like, I can email it to you this weekend. Just let me know.
Keith
Hey Jim
I was told by the bet baler mechanic in the country to always lock the plugger at TDC to make any adjustments.It's not that hard to do and will save a lot of greef.
(quoted from post at 10:39:46 11/23/11) Hey Jim
Maybe on a NH but not required on a JD. BTW what's TDC point of PH on a NH baler
Here ya go Jim.Note the notches in the frame .Put the rod between them and lock it down.I put vise grips on each side to hold it.Sorry about the fuzzy picture.
Always get a manual and always go thru the entire timing steps. Doing so will teach you how each part works so you can spot problems later on. Also, you will spot worn out parts faster too. Having a square baler work perfectly is not that hard to do and takes alot of stress out of the hay work.
