Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: Bush Hog Gearbox Oil
[Return to Forum]
MOTORCRAFTMAN
09-01-2011 10:50:00
74.176.187.241
I have a International 6ft IT-500 Bush Hog What should the level of Oil be in the Gear Box... and Type/Weight? HOW to measure it? Thanks Fellas' Larry KF4LKU
[Reply]   [No Email]
S2710
09-01-2011 15:18:08
98.143.227.89
 Re: Bush Hog Gearbox Oil in reply to MOTORCRAFTMAN, 09-01-2011 10:50:00
I have a old ford bush hog and about 3 years ago it started to leak. I put J.D. corn head grease in it and it has never lost any more. I figure if it is good enough for a high dollar corn head it is more then OK for my cheap bush hog.
Bob
[Reply]  [No Email]
johnemcn
09-01-2011 15:14:23
209.167.107.131
I have an IH #111 rotary cutter. When the gearbox began to leak (80W90), I simply pumped in grease and haven"t had any troubles.
[Reply]  [No Email]
Billy NY
09-01-2011 11:31:37
74.67.3.54
On the gear box, is there a small square plug and a large one, the small one when removed (if so on this model) would indicate the correct level of oil, some should spill out, if not top off, flip over unit, drain, change oil. I use Lucas 85W-140, or 90 wt. in my rhino, most I have seen use similar, my book called for 00 or 0 type lube, which is thicker, stringy/tacky, probably does not leak beyond seals, mine seems to not leak, seals holding. I could not find the 00 or 0 in small quantities, the Lucas works well and stays clean a good while, I do change mine annually, some never bother, each to his own.
One of my friends has a small 4'-0" model, not sure what kind, it has both plugs but the bottom one has a grease fitting, which probably was installed long after it left where it was built, or gearbox built. Some with leaky seals use cartridge grease when shaft seals leak.
Personally, I'd rather fix the seals, because who knows how many different kinds of grease, how much is in there, venting, and or mixing non compatible soap bases (different grease's mixed). What if you want to change or clean out the gearbox lube, potentially a mess, or maybe not ??? There may also be a vent in the filler plug, one of ours has that, let that get plugged and it pushes lube out somewhere. I've run these kinds of mowers since I was 10 years old, never had a gearbox failure. Many others use regular grease in them, I've always wondered if that lubes properly and or long term effects, as those gear boxes are kind of like differentials, all have an oil or something more viscous than grease when new, I believe, good for discussion, and also good to mention that I'm not familiar with IH models, but never let one run dry that is for sure.
[Reply]  [No Email]
BCnT
09-01-2011 19:22:15
68.65.150.242
 Re: Bush Hog Gearbox Oil in reply to Billy NY, 09-01-2011 11:31:37
i've got a Ford Sabre 5' shredder that my grandfather bought new in early '62...bottom seal went out in '65 and gearbox was filled with multipurpose grease...it got 3 more pumps of grease every couple months...i finally got tired of redecking it in '94 and bought a new one...the Sabre is still in pasture if i need it...gearbox is tight as day one.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
