Well, I finally figured out my plunger problems... RUST... The lower outer plunger rail has a whole 2 bolts still holding it (kind of) in position. Of course the results are alot of crud got under the rail, causing the plunger to be extremely tight. My big question now is do I:
1. Weld the rail down?
2. Drill holes thru the rail with counter sink and bolt it back down?
3. Remove the plunger, weld on new bolts to the underside and reinstll the Rail?
My biggest issue currently is time, i need to cut, and I can't cut until I have this thing working.... After 2nd cutting I can tear everything apart and make a better permanent fix.... Any thoughts??
