Swath Board For McCormick Deering Hay Mower.
I had made some for the Ford -Dearborn mowers for myself & others from the ntractor website . Not sure what size board you need or if mine would work . If you could get me a pattern or else measurements , I could make you one . HTH ! God bless
I make my own. I have a diagram for them. The diagram I have is for one off an A/C model B/C mid mount mower. If you would like a company just send me an e-mail asking for it and it is yours
I can not do it that way you have to send me one first. My e-mail is always open on Y-T and has been for years. If you use classic it is easy to email me but not sure on modern but think there is an option by my name
The board should have a metal band along the bottom of the wood.
What model of mower are you working on?
I have a pattern for the McCormick Deering. It should have a flat plate that bolts to the wood the mounts on the head of the cutting bar.
Dimensions are not critical. We used a #9, which I still have, when I was young. I made a swath board from whatever piece of scrap oak wood was around. 5 or 6 inches wide by 20 or so long. Important parts are the flat piece of steelwith holes to mount to the cutter bar and a center hole for the bolt that fastens the board to the cutterbar to go through. You need a heavy spring and assorted washers to fasten the board on. Spring is to let the board flex when turning and when hay is heavy. A piece of flat 3/4 or so wide thin steel along the bottom of the board protects it against wear. The above parts can be fabricated. More critical is a stamped steel bracket to fit a wooden rod in to help fasten the rod to the swath board at an angle, possibly 15-20 degrees. The last rod I made was from an old broken hoe handle with the rounded end still good. The rod is held on by 2 bolts with the factory metal piece having square holes so carriage bolts can be used so as not to catch on the hay. Wooden rod is sawed at an angle so it fits flat against the board and the metal piece fits flat against the board so tha hay dosen't catch behind them. Hope this helps.
KEH
