Yesterday's Tractor Co.
Shop Now View Cart
New Holland 451 Belt Number and Adjustments
07-11-2011 06:58:28
I just got out a NH 451 sickle mower from the shed and hooked it up. Is there a manual or a web site that may help me set up the mower so it will level out at a certain height? Right now it will level out but I think it is to close to the ground. If I raise it a little it will start to angle up. This is a tight machine with little wear however I need the belt number if anyone would have it. Thank You.
07-11-2011 20:10:05
 Re: New Holland 451 Belt Number and Adjustments in reply to eye4iron, 07-11-2011 06:58:28
Height should be 16.5" to the top of the cross frame. NH belt # is 63804. Mike
07-11-2011 09:24:02
The U shaped piece that has the latches on it controls the height of the shoe. If you look there are multible hole in that U. Just move the latch up or down as needed by using a different set of holes. That will change how close the mower is to the ground.
07-11-2011 10:50:02
 Re: New Holland 451 Belt Number and Adjustments in reply to Jdseller, 07-11-2011 09:24:02
Thanks I did see that U shape frame and the over center latches. This mower use to be on a 1850 Oliver. Now it is on a D-17 A/C. I guess it sits lower now. I will have to look at the adjustment and see if there is a hole left to raise it. Where can I find the belt number on the internet?
07-11-2011 21:25:24
 Re: New Holland 451 Belt Number and Adjustments in reply to eye4iron, 07-11-2011 10:50:02
alma tractor and equipment has all the parts for it.
