Loren in MN
Just picked up a very nice 2 bottom JD plow today. I was wondering what model it may be. On the main beams it has #583 on one and the other #623. It is a trip style ground lift plow with one high steel wheel on the left and a spoked rubber wheel (rubber needs replacing) on the right (is this correct?)..... plow shares/moldboards are excellent too.
I can say it was a very good day as I also picked up a JD #44 two bottom plow -says No.16 frame and No. 44. It may still have original paint and all plow share/moldboards are excellent and good tires as well.
The JD #44 looks newer, so I was wondering if it's any better?
Thanks for any info.....
Along with the plows were two JD model H style 50 manure spreaders (one good and one parts) and a JD tandem disc of about 9-10ft.
Brought home a 6 ton hay rack running gear and a 3pt back blade too.
Was a good day to stop at a garage sale!!!
