Ive got an old Case running gear that has both front spindles stuck TIGHT. Hooked a come-along to the tie rod hole and to a JD A and the wagon frame to a truck and started sliding the front of the A sideways...
Both spindle pipes have been welded/replaced at some point and the gear itself is pretty rough, but if I could get these spindles to break loose I would still like to use it. I've heated it and boiled the grease and PB Blaster runs through the spindles, but they still aren't budging. Any suggestions? It getting scrapped soon otherwise.
Thanks
Thanks
