309 planter rebuild
SuperHank
I will start to rebuild my 2 row Ford 309 planter this week and I wonder how much experience the readers have with using the rust killing paint like Ospho(sp?) or naval jelly etc to kill existing rust and provide a better base to paint and prevent future rust. Also I have to rebuild the fertilizer distributor and I will need an axle to rebuild. If I can find stainless I use it but is there a better or as good choice to prevent rust in the fertilizer box. I painted and sprayed to wash it out but it finally rusted thru.
I bought a Dearborn 12-xx 2 row planter about 10 years ago. It was the predecessor to the Ford 309. When I bought it, nothing moved except the drive wheels/axle. It was completely rusted together. I unbolted everthing, took it all apart down to the individual piece, and used the electrolysis method for rust removal on all the medium and small pieces. For larger pieces, I just used a wire wheel on a drill or angle grinder.
I have restored 3 John Deere running gears, 963, 953, and a 952. I sandblast the bolsters, standards, and wheels and then wire wheel the rest of the gear with an angle grinder. On the wire wheeled parts I paint with 2 coats of RustOleum Rusty Metal Primer and finish with 2 coats of John Deere oil-based paint. On the sandblasted parts I paint with 2 coast of RustOleum Clean Metal Primer and finish with 2 coats of John Deere oil-based paint. The RustOleum Rusty Metal Primer is somewhat thicker than normal paint and covers very well. There may be better solutions but this has worked very well for me.
I restored my 309 a few years ago, I compleatly dissamembled and sand blasted everything. Then to kill whatever fertilizer may still be on there I washed in soapy hot water with a bit of baking soda. To protect it I started with a Zinc rich primer (Carboline), It is an industrial coating. A good etching primer will work too. Then paint with your favorite brand of paint. I used Rustoleum Implement paint, comes in Ford Blue, the Grey was paint from NH Dealer, "63-"00 Ford Grey. If anything is broke, good luck on parts, most are NLS. This how mine turned out
Nice job ; that's exactly the result I'm looking for. The fert distributor shaft is looking like a problemfor me.
superhank - I rebuilt my 309 6 years ago. The feeder shaft was pretty well shot. I cut 1" pvc pipe to fit each section between the rubber wheels, ripped a gap down one side of maybe 1/2", secured this around the shaft open side up, then poured marine epoxy with fiber filler into each section, excapsulating the rusty remnants of the shaft. That was 6 years ago, it lives outside from April to August, and plants 3-5 acres of corn, milo and beans each year. Might be your salvation. Messicks website has a search engine under New Holland for part numbers. The Feeder Shaft is part #222314. Many 309 parts still available, but it's cheaper to pay a shop to fabricate than buy the parts IMO.
(quoted from post at 17:02:50 02/08/11) I will start to rebuild my 2 row Ford 309 planter this week and I wonder how much experience the readers have with using the rust killing paint like Ospho(sp?) or naval jelly etc to kill existing rust and provide a better base to paint and prevent future rust. Also I have to rebuild the fertilizer distributor and I will need an axle to rebuild. If I can find stainless I use it but is there a better or as good choice to prevent rust in the fertilizer box. I painted and sprayed to wash it out but it finally rusted thru.
I got a piece of 5/8" stainless shaft and had them cut some stainless washersto go on either side of the rubber flap wheels. Was only about $40 for all. I used stainless cotter pins to hold the flap wheels in place.
Works great
