Plow Share?
I have a 1950 IH one bottom pull type plow. The share is worn out and I would like to purchase another.... new or good used. I haven't had any luck finding any. On my share is stamped " SOLID IH 0B556" and there is a heart symbol following the numbers.
Does anyone know where I can get this share?
Thanks
If this is a plow you use for work rather then show then just go get any old share and blow a couple holes in the right spot with the torch and bolt it on there. You won't live long enough to ware the heads off the bolts. And if you do just put in a couple new bolts. I've done that on several old plows and been taking them to plow bees for 20 years and you can still get a wrench to hold on the flats.
