Farmall A-16 Mower belt (length)
hayrake25
Hello. I want to pick me up a belt for my Farmall A-16 Mower at my local NAPA auto parts store. Can you all tell me what size that I need to purchase or if you happen to have a part number for NAPA would appreciat that also. THANKS
Do you have the iron ends of the pitman? I may have a used one here somewhere. I have NOC pitmans for older horse mowers but I'm still not sure which models except for a couple I identified as fitting a JD #2 mower. Most are IHC but don't know the model.
(quoted from post at 08:49:45 02/03/11) That would be a good idea if it still had the belt on it. Also it is missing the pitman arm
I can get a 81C45 pitman stick assembly, but I'm not sure if that is the correct stick for your mower. I'm sure I can get the belt also if I just knew a part number or the dimensions.
