This old set of MF62 plows makes a better trash drag than plow.
So I replace the coulter blades and set them at 6" off the ground. I can pull the plows at around 7" deep with my TO-35 Fergy.
I seems the trash builds up in front of the coulter frames then plugs up the plow, as more trash builds up it lifts the plow out of the ground.
if the new coulters blades do not help with trash buildup, wonder if you could weld a angle to the front of the coulter frame to guide trash down under the coulter frame.
other wise i am out of solutions.
I always bushhog the garden spot then disc it mulit times before I attempt to plow the filth under.
any suggestions are appreciated:
