I was working on plowing fot the first time today with my grandpa so we borrowed a neighbor"s 2-14 IH to go behind our 1937 JD A. It was doing a decent job in an old pasture where we started, but there was a tough spot where a fencerow had been where it kept tripping. I would simply hook up again and ease it through. One time it hooked a big rock and ended up pulling it out, and after that we couldn"t get it to go in the ground right. We were still making adjustments at this time so we didn"t immediately notice because we thought it was something we adjusted.
What are some good rules of thumb to get the plow set? (just start from the beginning if you need to. Hitch, levers etc.) We went to the bean field after that to try to get it back right (softer soil) and we could never get it more than 4 inches deep. The plow wanted to pull to the land side badly and the tail wheel was riding outside of the furrow. It also was doing a "nosedive" and the back moldboard was hardly cutting.
I"m not sure what happened but it was working much better when we started. I couldn"t find and bent/broken parts. The only thing we could see was MAYBE the front share tip was SLIGHTLY bent down, but not sure.
Thanks for any help
Ih plow look like this one
Thanks for any help
