Massey Ferguson #9 Hay baler
Mike Huber
08-29-1998 03:43:10
I just bought my first MF hay baler I'll be using it for my 3rd cutting of hay this year, is there any thing I should know about this baler Thanks Mike Huber
Dennis
09-11-1998 17:43:28
 Re: Massey Ferguson #9 Hay baler in reply to Mike Huber, 08-29-1998 03:43:10
: I just bought my first MF hay baler I'll be using it for my 3rd cutting of hay this year, is there any thing I should know about this baler Thanks Mike Huber
Mike, I too had a MF 10 baler and used it alot. Upon buying it I totally went through it with paint and chains and such... the only drawback to them I saw was the inconsistentcy of the bale length and the absolute need to have text book windrows to get a good bale. The last point is a laugh, that baler absolutely hated my wife to the point I thought it was "demon's posessed". It would bale 200-300 bales without incident and if she walked out into the field it would drop one after another to where I'd just have to stop until she left, then (without touching the baler)I could go back to normal performance. Hope all of this but the last part helps, Dennis
Nellie
09-03-1998 14:52:19
:I had a MF 10 for yrs. make sure the chains are in good tension. I loved the knotters, they just worked great. The problem i got into was the hay feeder arms got too much side play. There is no grease points for those arms. If you find the bushing need to be replaced do it this winter because once they get so lose they will crash (Side to side movement too much) ontop of the baler breaking chains bending things up. At the age of this baler fixing after a major crash becomes too expensive
Paul
11-23-1998 23:12:44
 Re: Re: Massey Ferguson #9 Hay baler in reply to Nellie, 09-03-1998 14:52:19
I have a MF 10 that I use for a backup to my John Deere.I took the packer forks apart and drilled holes and tapped them with a 1/4" fine thread tap and put grease fittings in them,one on each side of each packer fork.There are also a lot of bronze bushings in those balers.I go to King Bearing(or any big bearing house) and order them by demensions.If I can only get one that is longer,I just cut it off.Much much cheaper than dealer bushings.
: :I had a MF 10 for yrs. make sure the chains are in good tension. I loved the knotters, they just worked great. The problem i got into was the hay feeder arms got too much side play. There is no grease points for those arms. If you find the bushing need to be replaced do it this winter because once they get so lose they will crash (Side to side movement too much) ontop of the baler breaking chains bending things up. At the age of this baler fixing after a major crash becomes too expensive
: : I just bought my first MF hay baler I'll be using it for my 3rd cutting of hay this year, is there any thing I should know about this baler Thanks Mike Huber
Binder Driver
09-01-1998 17:33:28
I live on the missouri river bottom in south dakota and we are the countries leading source of hay and i have never seen a m.f. baler
fdga
04-15-2003 08:36:46
 Re: Re: Massey Ferguson #9 Hay baler in reply to Binder Driver, 09-01-1998 17:33:28
this baler is n't very good i would n't buy it if i had to
asd
04-15-2003 08:37:38
 Re: Re: Re: Massey Ferguson #9 Hay baler in reply to fdga, 04-15-2003 08:36:46
nice baler
