Farmhand F11 loader
Anonymous-0
I have an F11 loader with a bad lift cylinder. When cold, it leaks oil like there are no seals in it. Doesn't leak much when the oil gets warmed up. This is after I had the seals replaced. The ram is bent a little and the chrome is dinged up. Where can a guy get a replacement ram? It's usually not a big deal, but I have been out moving snow every day lately. Thanks.
I'd be checking the local yellow pages for a hydraulic repair shop. They can get rams for most anything.
I know it"s unlikely you"re anywhere near the west coast, but I"ve got two cylinders I pulled off an F-11 I junked last year. Both in good shape...
Ben
I used to work for AGCO and worked with the Farmhand loaders. You should be able to contact an AGCO dealer for parts. I went to AGCO website and you can look at Farmhand parts books free of charge.
M.Miller
we have local hydraulic shops that will make you these type things, normally pretty reasonably priced too
No big deal if the shaft is bent unless it is bent very bad. Then just straighten it as best you can. The dings and marks in the chrome can be cleaned up good with thinner and then filled with liquid steel or epoxy. Let them harden for two days and file down with emery cloth. Pop in a new seal kit and your good to go.
