Anonymous-0
I just got it pulled in here last week the day before 26 in of snow came. I am itchin' to start working on it. They told me the pick up part was busted, and the vee belt is off of it. I have looked it over and can't see anything that is obvious. Would it be stupid to it it to the tractor and try to run it . It has been sitting out in a field fot 2 years since it broke. It is a 505 g. I think the paint is original and the bearings all have yellow paint on them. Which make me afraid they are all going to start going bad as we start useing it, or I am hoping it may not have all that much use and they will be Ok. One of the rollers has zerk fitting on the bearings. also is this baler unlike our previos Hesston where you had to leave it cracked open the keep the tension off the belts when not in use. Thanks
