5' King Kutter Bush Hog...???
KRS_MED
A friend gave me a 5' King Kutter Bush Hog and the blades look to be very dull. I have seen them with a sharp edge and with a blunt edge. Can they be sharpened, or just best to replace them? Also what size socket does it take to remove the blade?
Thanks Very Much!
Keith
i sharpen mine till theyre gone...if ya got boo-coo money i guess you can just replace.
i never have taken blades off my newest shredder...just sharpen em while theyre on...8" c clamp tightened under deck gives me a back stop to hold blade while i grind...ALWAYS block shredder up on sturdy blocks...NEVER trust the hydraulics.
I always take the shredder off the tractor then flip it up on its side and grind down the blades until pretty sharp. You dont want them really sharp b/c then you will just dull them real quickly. I learned a die grinder works best, but if you dont have one a angle grinder works fine also.
