Hahn Hi-Boy Sprayer
garytomaszewski
04-13-2008 18:19:04
100 gal + or -, Tricycle, 4 cylinder Wisconsin VF-4, Hahn pump. All I know. Can anyone tell me about the Transmission shift pattern and approximate speeds? It seems to have 5 forward speeds and 1 reverse. Thanks
Greasey Hand
04-15-2008 04:17:50
 Re: Hahn Hi-Boy Sprayer in reply to garytomaszewski, 04-13-2008 18:19:04
Mine has a 4 cyl ford motor. Thought toe tank was like those ovel fuel barrols 265 gal only ss.
al the drive things a ford trans rear end master cyl. I would like to make mine wider wheel stance in the rear, so it would be more stable.
would have to make longer splined drive shafts.
do you think its a good iadea?
Tom from IL
04-13-2008 19:05:31
The Hahns we had were 200 gal tanks. Engine was Wisconsin VH4D, 30 hp. Tranny was 4 sp with 4th gear blocked out--too fast for safety. I usually sprayed in 3rd gear at about 8 mph. If memory serves, shift pattern was like this: -R 3--4(blocked out) 1--2
Basically an old truck tranny turned sideways>
Hope this helps
Tom
garytomaszewski
04-13-2008 19:53:16
 Re: Hahn Hi-Boy Sprayer in reply to Tom from IL, 04-13-2008 19:05:31
Guessed at tank size, but looks like all the Hahns I remember seeing so probably is 200 gal. THANKS that shift pattern is what i was looking for, mine will go straight across from reverse and all positions appear to turn drive sprocket, which made me think 5 forward.
