Howse Mower with Agmo Gearbox
C Watts
04-12-2008 13:53:41
I have a 5 ft Howse 500 rotary mower (brush hog type) with an AGMO R-45-312 gearbox. It is leaking fluid around the (horizontal) input shaft. Does anyone know where I can get parts (input shaft bearing or seal) or repair information?
Thanks,
Craig
BCnT
04-12-2008 17:13:32
 Re: Howse Mower with Agmo Gearbox in reply to C Watts, 04-12-2008 13:53:41
well since we've heard from Kentucky...this Tejas long haired redneck says same thing...fill it with grease...i got a lil 5 foot shredder that developed a leak about 30 years ago...i drilled and tapped fill plug for a grease zerk...filled it up and give it a squirt or 3 whenever i think about it...i've heard good things about that cornhead grease too...buddy of mine runs it in his Harley Panhead tranny...one of the few Pans i know of that dont mark its spot.
Craig Watts
04-13-2008 07:27:19
 Re: Howse Mower with Agmo Gearbox in reply to BCnT, 04-12-2008 17:13:32
Thanks to the both of you, from wherever you hail and whatever your stripe. I'll try the grease in the gearbox and mow some grass.
Fred T. Hart Jr.
04-12-2008 14:50:28
I am just a KY redneck, but I solved that problem by filling my cutter gearbox with grease. Must work OK as it has been in gearbox for years and I have had no problems.
Got the idea from a TN redneck, he could not keep the gearbox from leaking on his NEW Holland hay rake, so he filled it with grease.
Others have filled the leaking steering boxes on their little Ford/Ferguson tractors with John Deere corn head grease, say it works fine.
Craig Watts
04-21-2008 11:00:35
 Re: Howse Mower with Agmo Gearbox in reply to Fred T. Hart Jr., 04-12-2008 14:50:28
UPDATE: Thought I'd let you know. Thanks to the advice given on this board, I cut my own gasket, put it all back together, and added some grease to the gearbox. I've mowed a total of 7 acres in three different fields for myself and my neighbors without a drop since.
Thanks,
Craig
