TractorLinks.com
Rotary Cutter Tail Wheel Suppliers ?
Billy NY
08-15-2007 11:03:53
Probably the dumbest thing I've done in awhile, lost the tail wheel on the older model Rhino SE-6 and ran it over on the return pass ! Should have replaced that pin, wheel fell off, was gettin dark, decided to make that last pass, not good. Bent the rim, rest is ok, fork has a gouge in it, boy that'd do a number on a person, bent the side wall out too. Made quite a rumble, nothing sheared though.
Question is, any suppliers of these on the net, it looks like the rim detatches from the wheel/bearing assembly, whole ring of bolts, ones I have seen only have 4 or 5 bolts, wondering if it might be specific to Servis Rhino or what, be nice if TSC had something on the shelf, could modify one, not the end of the world, assume TSC replacement cutter blades to be ok quality, really a bummer as I took good care of this unit, bent blade must be the new vibration I noticed, if that's all, should be no problem to repair, side wall should pound back in place, few whacks with a sledge and block of hardwood ought to do it, what a dumb@ss move though, darned pin was worn and I knew it.
Larry T
08-16-2007 18:02:24
 Re: Rotary Cutter Tail Wheel Suppliers ? in reply to Billy NY, 08-15-2007 11:03:53
If you cant find one locally you might try King Kutter. from the picture it looks identical to the tail wheel on my King Kutter. Larry T
Farmerfred
08-16-2007 07:31:08
No one has mentioned A&I. aiproducts.com
Log on and get a quote from a dealer near you!
Billy NY
08-16-2007 07:51:31
 Re: Rotary Cutter Tail Wheel Suppliers ? in reply to Farmerfred, 08-16-2007 07:31:08
I checked that site out, do appreciate all the links, always bookmark them, there are dealers nearby, even found the information needed to find that other place I heard about for implement parts with a large inventory, they too are a dealer, much appreciated, something will turn up I'll bet.
Billy NY
08-16-2007 05:52:28
 Re: Rotary Cutter Tail Wheel Suppliers ? in reply to dobber, 08-15-2007 22:21:51
Turns out the Kubota dealer nearby is a Tisco dealer and so is the rental house I deal with, something will turn up, also have an implement dealer somewhere near here that I've never been to that is rumored to have an extensive inventory, used and salvage, need some parts for my set of disc's too, idiot at the farm broke a disc off one end of the front gang on one end.
Dave Anderson
08-15-2007 16:17:51
Try Agri-supply.com. I don't know what size you're looking for, but the wheel that fits a 5' bush hog is about $25.00 there.
Billy NY
08-16-2007 06:53:09
 Re: Rotary Cutter Tail Wheel Suppliers ? in reply to Dave Anderson, 08-15-2007 16:17:51
Reverse side, showing solid piece with bearing axle, rim must seperate from this, would be nice to find just that rim with the tire segments.
Billy NY
08-16-2007 06:41:48
Here is the freshly mangled tail wheel, bolt pattern on this side shows the joint between what looks like the rim that holds the segments, with the flip side just showing the bolt heads, one piece with the bearing/axle that pins to the fork
Billy NY
08-15-2007 20:17:19
It's a 15" wheel for a 6'-0" cutter, looks like the rim comes off, (splits in half vertically) but the axle bearing assembly is still part of the wheel, vs. it being a hub, trying to find a match to that, wide diameter hole with ring of bolt holes, most of what I've seen has a smaller diameter hole, whereas this one is larger, with an entire radius of small bolts holding it to the other half of the rim which has the axle & bearing, vs. the 4 or 5 bolt patterns I keep findinf, they have the smaller dia hole for a hub arrangement if I am correct. It must be a different kind of wheel or specific to Servis-Rhino, worst case it's either super expensive, can't be found and I'll just have to drop another tail/fork assembly in, pin is probably same diameter, could make one too, but really just need a wheel with tire segments.
While searching the net, I finally spotted an operators with parts catalog manual for it, one of the few things I have that I had no manual for, so that might help with part numbers.
I'll check out that link, thanks again !
hay
08-15-2007 12:01:58
most tractor dealers can order parts from most any brands. TSC would be my absolute last resort because of their poor quality merchandise.
old
08-15-2007 11:20:18
Any good farm/home place should have all the stuff you need. If that doesn't work most tractor dealers will have or be able to get what you need but of course if you go to a tractor dealer be ready to pay more for the stuff. Even this site and or value bilt will most likely have what you need
Billy NY
08-15-2007 11:57:28
 Re: Rotary Cutter Tail Wheel Suppliers ? in reply to old, 08-15-2007 11:20:18
How'd I forget V-Bilt ? I got brake drums from them for my 850 3 years ago, which I highly recommend, they looked better than the originals, made in Turkey. The bolt pattern threw me off on this tailwheel rim with tire segments, does not look as generic as the ones I've seen. I'll see what TSC has, hit those dealers as a last resort as usual, can't be all that different unless they are specific to Rhino, assuming the pin diameter is the same, just put a new fork/wheel assembly on there, I think I can straighten the wheel out for the time being, big slice in the tire segments though, makes you respect those blades that is for sure.
