JD 350 sickle bar mower question
tom in VA
04-19-2007 15:24:06
Dealer has a JD 350 sickle bar mower for sale. I need a mower to cut ditch banks from topside down. Will this mow on an angle below horizontal? If so, how far below leval? Portions of my ditches are almost 45 degrees below levall. The dealer could not answer the question and did not have a good area to hook up to a tractor and test.
dorsetfarmer
04-23-2007 12:03:50
 Re: JD 350 sickle bar mower question in reply to tom in VA, 04-19-2007 15:24:06
You'll be limited by the chain length that raises the cutter bar head. This is adjustable, and one can extend it, but you'll then lose a bit on the height that the end shoe can be raised. I'd recommend a manual, and a 7 ft. mower is fine, but a 9 ft is too much bar for the break-back mechanism. Certainly, one can mow at a downward angle, and if you can get the rear wheel of the tractor on the same slope, then the whole unit is basically in line. If the heel goes over an elevation, it will prevent the end shoe from tracking down on the ground below horizontal. I've been pleased with mine, and the prices have dropped like a rock post-disc mower invention.
Bob
04-20-2007 12:37:10
The 350 is a "pitmanless" mower, and will cut at any angle that the cutter bar can physically pivot to.
Beware... the drive "head" on those can wear out and is $$$$$$$$$$$$$$$$$$ to rebuild.
david from mo
04-19-2007 16:32:20
From my manual 45 degrees up 30 degrees down
RayP(MI)
04-20-2007 19:07:55
 Re: JD 350 sickle bar mower question in reply to david from mo, 04-19-2007 16:32:20
In actual practice, I haven't been able to do this great a range of angle, due to suspension system, which lifts mower when 3pt hich is rasied.
Rome
04-19-2007 16:31:23
John Deere owners manual for the 350 mower shows these specs with inner shoe at ground level.
Cutting range : 45 degrees up / 30 degrees down. Unit weighs 630 lbs.
