ford corn planter seed plates
McCullough
01-03-2007 17:33:37
Do you guys know if Ford 309 and John Deere corn planter seed plates will interchange? I have a Ford 309 planter hard to find right size plates for sweet corn a lot of differant sized seed. I plant 3-4 differant varieties. When I do find Ford plates they are big $$$. Thanks for help.
Al McCullough
Brendon
01-05-2007 03:35:28
 Re: ford corn planter seed plates in reply to McCullough, 01-03-2007 17:33:37
The Lincoln Ag Products website states that the Deere plates will fit a Ford 352 planter but nothing is mentioned about the 309. I'm not educated on the Ford planters so I don't know what the differences are between the 352 and 309.
hhf
01-05-2007 02:38:32
Al, I used to have a 309 planter that I used to plant sweet corn. I still have seed plates hanging in the shed for it. If your interested, tomorrow I will check them out and see what sizes I have.... I beleive I have everything from small to large round. Email me, Tom
Steve in Colo
01-04-2007 18:01:45
There are some ford plates on ebay, go to farm equipment,planters. I belive they were sweet corn plates.
Easy1
01-04-2007 08:38:30
I used to have a Ford 309 planter. The plates were very expensive. I tried Lincoln ag products, but nobody there would tell me if the plates would fit the 309. I sold the planter and got a John Deere.
LA in Wi.
01-04-2007 08:00:14
Al,
Go to your "Search" thingy, then type "Lincoln Ag Products". That website gives you the info you are looking for. It lists plates for nearly every plate planter made.
LA in Wi
Leroy
01-04-2007 05:48:47
The Lincoln plastic plate size chart does not list them for ford but I think that they list with an adapter for plates in oliver of some models, Oliver may have made the ford planter. I know they with adapter fit AC so the only thing I would say is get in touch with maker of the plates and see what they say. If the diameter is the same (I think doughtful) then you could make a drive adapter. I could measure the deere diameter but do not know the diameter of the ford plates.
